Vertical
A vertical closed loop field is composed of pipes that run vertically in the ground. A hole is bored in the ground, typically 75 to 500 feet (23–150 m) deep. Pipe pairs in the hole are joined with a U-shaped cross connector at the bottom of the hole. The borehole is commonly filled with a bentonite grout surrounding the pipe to provide a thermal connection to the surrounding soil or rock to improve the heat transfer. Thermally enhanced grouts are available to improve this heat transfer. Grout also protects the ground water from contamination, and prevents artesian wells from flooding the property. Vertical loop fields are typically used when there is a limited area of land available. Bore holes are spaced at least 5–6 m apart and the depth depends on ground and building characteristics. For illustration, a detached house needing 10 kW (3 ton) of heating capacity might need three boreholes 80 to 110 m (260 to 360 ft) deep.[12] (A ton of heat is 12,000 British thermal units per hour (BTU/h) or 3.5 kilowatts.) During the cooling season, the local temperature rise in the bore field is influenced most by the moisture travel in the soil. Reliable heat transfer models have been developed through sample bore holes as well as other tests.
http://en.wikipedia.org/wiki/Geothermal_heat_pump [5]
I dajte ljudi, drž'te se znanosti i prakse.
A nijedan veze sa vezom nema.
Molim te reci mi pomocu koje formule si izracunao koliki mu je izmenjivac potreban???
Ne pitam te zbog sebe,jer ja odlicno znam te racune,nego zbog naseg nesudjenog Klimatizera,cisto da ne kopa do Kine ne bi li napravio dobar izmenjivac.
