AVD Weight and Volume Calculator v7.1.1 | 4.14 Mb
AVD Weight and Volume Calculator is just the thing for measuring physical parameters of composite objects in 3-D. It calculates weight, volume and mass for the figures of various shapes. The process of calculation is quite simple: after you select the object's shape, just define the sizes with the number of parts and press "Calculate" button to get the result. The ability to process three dimensional composite objects, even those which have apertures, expands the sphere of the program's usage as you will be able to work out physical parameters of objects of most diverse shapes. The program includes such structural units as: plate, pipe, bar, beam, channel, angle and others.
You will certainly appreciate the ample choice of units provided by the program. The list of units is truly impressive as it encompasses almost every unit of both Imperial and metrical unit system. Also, at any time you can use the built-in unit converter that will redeem you from the need of transferring numbers from one system to another by yourself. What's more, the result of any calculation can be presented in any units you require.
AVD Weight and Volume Calculator also takes into account density of the material of a given structure. For your convenience the program includes a number of widespread materials and allows adding new materials and deleting those, which you don't find necessary.
The creators of AVD Weight and Volume Calculator took into account the human factor, so in case of some contingency (e.g. if you make a typo or add a wrong object), you can undo the operation. Also, when calculations are done, you can save the results to a text file or send them directly to print.
The ease of usage and a wide variety of included objects and units in combination with the ability to work out physical parameters of objects with apertures make AVD Weight and Volume Calculator a handy helper in the sphere of engineering, architecture and exact sciences.
Features:
Common shapes library.
Common materials library. You may modify this library, add or remove any of the material on this list.
Internal units convertor
Metrical and American/English units.
Undo operation
Print result
Save result as .txt file
http://depositfiles.com/files/okx5et0nw<br /> ili<br /> <a href="http://sharingmatrix.com/file/15039609/Avlan.Design.AVD.Mass.and.Volume.Calculator.v7.1.1.WinAll.Cracked-CRD.rar" title="http://sharingmatrix.com/file/15039609/Avlan.Design.AVD.Mass.and.Volume.Calculator.v7.1.1.WinAll.Cracked-CRD.rar">http://sharingmatrix.com/file/15039609/Avlan.Design.AVD.Mass.and.Volume....</a><br /> ili<br /> http://www.unibytes.com/RPiIzbbhwQ-B
Avlan Design AVD Mass and Volume Calculator v7.1.1-CRD | 4.6 Mb
AVD Mass and Volume Calculator is just the thing for measuring physical parameters of composite objects in 3-D. It calculates weight, volume and mass for the figures of various shapes. The process of calculation is quite simple: after you select the object's shape, just define the sizes with the number of parts and press "Calculate" button to get the result.
AVD Mass and Volume Calculator also takes into account density of the material of a given structure. For your convenience the program includes a number of widespread materials and allows adding new materials and deleting those, which you don't find necessary.
The creators of AVD Mass and Volume Calculator took into account the human factor, so in case of some contingency (e.g. if you make a typo or add a wrong object), you can undo the operation. Also, when calculations are done, you can save the results to a text file or send them directly to print.
The ease of usage and a wide variety of included objects and units in combination with the ability to work out physical parameters of objects with apertures make AVD Mass and Volume Calculator a handy helper in the sphere of engineering, architecture and exact sciences.
Homepage: http://www.avlandesign.com/calc.htm
http://sharingmatrix.com/file/15016733/Avlan.Design.AVD.Mass.and.Volume.Calculator.v7.1.1.WinAll.Cracked-CRD.rar<br /> ili<br /> <a href="http://hotfile.com/dl/58090640/9b64af5/Avlan.Design.AVD.Mass.and.Volume.Calculator.v7.1.1.WinAll.Cracked-CRD.rar.html" title="http://hotfile.com/dl/58090640/9b64af5/Avlan.Design.AVD.Mass.and.Volume.Calculator.v7.1.1.WinAll.Cracked-CRD.rar.html">http://hotfile.com/dl/58090640/9b64af5/Avlan.Design.AVD.Mass.and.Volume....</a><br /> ili<br /> http://www.fileserve.com/file/ByP3muq/Avlan.Design.AVD.Mass.and.Volume.Calculator.v7.1.1.WinAll.Cracked-CRD.rar
Šta sa masom i zapreminom?
