Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:a2463717fd1133d7c8cb887e261595d7'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', � in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:806:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Majstor što je radio WC stavio mi je u isti 5*1.5mm2 umjesto 3*2.5mm2 za veš mašinu, kaže nestalo mu ovoga pa može i ovaj, mašina ima 2700 W, e sad on kaže da je 2 crne spojio zajedno i to je faza i a smeđu i plavu zajedno i to je Nula, dok je žutozelena uzemljnje...ovako ispada da je to kabel 3*3mm2(tj 1,5 je uzemljenje)...može li ovo ovako ostati pošto mi je sad nezgodno provući novi kabel...veš mašina nije u stalnom pogonu i on tvrdi da je i 3*1,5mm in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:c5a04146d0d9be02a6bc415f76b260d8'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', � in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:680:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Kao što je netko već dao negdje tabelu, I=P/U tj 2700/220=12,2 A...pravi bliži bi bio 15 A što znači da bi čak 3*1,0mm2 mogao zadovoljiti potrebe veš mašine, ali stavlja se 3*1,5mm2 jer taj 3*1,0 nema..tj barem nije standard u elektroinstalacijama ako ga i ima...a taj 5*1,5 sa po 2 žice na fazu i nulu će raditi pouzdano i bez problema!...Nadam se da sam pomogao...pozdrav!</p>\\n ', created = 1748726714, expire = 1748813114, headers = in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:23b817740e86635071f9c348429d2503'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', � in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:536:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Da li je u pitanju <span style=\\"text-decoration:underline\\">samo</span> odovod struje za ves masinu? Koji je presjek dovodnog kabla? Ili je isto isao s uduplanom 1,5.<br />\\n I ima li jos potrosaca na tom kablu?</p>\\n ', created = 1748726714, expire = 1748813114, headers = '', serialized = 0 WHERE cid = '3:23b817740e86635071f9c348429d2503'\&quo in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:182c6a82eb0b22f8e24b02bb7ac09eff'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', � in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:339:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>znam o svemu pomalo - a u biti znam...nista</p>\\n ', created = 1748726714, expire = 1748813114, headers = '', serialized = 0 WHERE cid = '1:182c6a82eb0b22f8e24b02bb7ac09eff'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/foru in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:06517a23ab2c550568c537d68b85e625'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', � in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:697:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>5*2.5mm2 je dovod za kupatilo...al nekako se zajeblo pa umjesto 3*2.5 do mašine otišao 5*1.5mm2...napominjem da je ranije godinama na istoj mašini bio 3*1.5mm2 i nije bilo nikad problema....tako da ovo 5*1.5mm2 vjerujem neće stvarati probleme...mislim da je boljen da budu uduplani na utičnici po 2 žice (2*1.5 za faza isto tako i za nulu) nego da budu samo 3*1.5mm2 a dvije da ostaniu slobodne?</p>\\n ', created = 1748726714, expire = 1748 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:342df790de56851d10b85090b520d4b1'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', � in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:329:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Ma nemaš tu problema, uživaj...</p>\\n ', created = 1748726714, expire = 1748813114, headers = '', serialized = 0 WHERE cid = '3:342df790de56851d10b85090b520d4b1'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjev in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:eb1e8720a9a221d6b268701fceb5b230'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', � in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:591:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p><a href=\\"http://www.automatic-house.rs\\" title=\\"www.automatic-house.rs\\">www.automatic-house.rs</a><br />\\n<a href=\\"http://www.automatic-house.rs/blog\\" title=\\"www.automatic-house.rs/blog\\">www.automatic-house.rs/blog</a></p>\\n ', created = 1748726714, expire = 1748813114, headers = &#0 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:7f019214e5999b7e839202b870312646'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', � in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:801:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p><a href=\\"http://www.automatic-house.rs/blog\\" title=\\"http://www.automatic-house.rs/blog\\">http://www.automatic-house.rs/blog</a><br />\\n<a href=\\"http://www.motorizakapije.com\\" title=\\"http://www.motorizakapije.com\\">http://www.motorizakapije.com</a><br />\\n<a href=\\"http://www.elekt in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:e7641e9a6354219dd180b953092c228f'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', � in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:602:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Pozdrav svima,</p>\\n<p>Novi sam na ovom forumu i mnogo mi je koristio, dok sam iscitavao pojedine teme...<br />\\nS obzirom da i ja pomalo radim instalacije, sta mislite , da li sam pogrijesio sto sam do kupatila doveo samo jedan 5x2.5 mm kabl</p>\\n<p>POzdrav<br />\\nOtto</p>\\n ', created = 1748726714, expire = 1748813114, headers = '', ser in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:cd632d6c9ec4cb16401458ad1a487178'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', � in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:518:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Mislim da nisi pogrešio, jer je ukupna instalisana snaga u kupatilu, računajući bojler, mašinu za veš i fen eventuano do 6 ili 7 kW, a to taj kabl može da podnese, pogotovu što neće sve biti istovremeno uključeno.</p>\\n ', created = 1748726714, expire = 1748813114, headers = '', serialized = 0 WHERE cid = '3:cd632d6c9ec4cb16401458ad1a487178'\";s:5:\"%file\";s:76:\"/home/admin/do in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:311635b68c9f5be8fad38f70a9f701f7'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', � in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:541:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>[marq=left]<span style=\\"color:blue\\"><span style=\\"font-weight:bold\\"><span style=\\"font-style:italic\\">Uradi sam, ali bez znanja i alata nema zanata!</span></span></span>[/marq]</p>\\n ', created = 1748726714, expire = 1748813114, headers = '', serialized = 0 WHERE cid = '1 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:f0da8a98e1c6682beb3cd064732e4fc0'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', � in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:409:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Без алата нема заната, a без знања ни најбољи алат неће помоћи..</p>\\n ', created = 1748726714, expire = 1748813114, headers = '', serialized = 0 WHERE cid = '3:f0da8a98e1c6682beb3cd064732e4fc0'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}', in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:68967f390901ff04966e0ebe36f510b7'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', � in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:548:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>pozdrav Oto,nisi nista pogresio sto si doveo 5x2,5 do kupatila,jedna faza za bojler,jedna za ves masinu i jedna za grejalicu a za svetlo i sijalicu na umivaoniku uzmes fazu koja nije za bojler,i naravno nula i uzemljenje.samo napred i provereno je.pozz</p>\\n ', created = 1748726714, expire = 1748813114, headers = '', serialized = 0 WHERE cid = '3:68967f390901ff04966e0ebe36f510b7'\";s:5:\"%file\&qu in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:225f7bf3986fc5e3882a3424da10510e'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', � in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1336:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p><div class=\\"bb-quote\\"><b>zegel wrote:</b><blockquote class=\\"bb-quote-body\\">pozdrav Oto,nisi nista pogresio sto si doveo 5x2,5 do kupatila,jedna faza za bojler,jedna za ves masinu i jedna za grejalicu a za svetlo i sijalicu na umivaoniku uzmes fazu koja nije za bojler,i naravno nula i uzemljenje.samo napred i provereno je.pozz</blockquote></div&am in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:9ff7f8a895930c958cceee7947341b73'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', � in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:536:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Nisi pogriješio što se tiče opterećenja i nije bitno s koje faze ćeš odvesti na sijalicu ali s majstorske strane praktikuje se da se sijalica i utičnice razdvajaju znači po nekim propisima si trebao dovesti 5*2.5[mm^2] i 3*1.5[mm^2]</p>\\n ', created = 1748726714, expire = 1748813114, headers = '', serialized = 0 WHERE cid = '3:9ff7f8a895930c958cceee7947341b73'\";s:5:\"%file\";s:76:\&q in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:5d3024d077466ce31cea2716baf4e76f'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', � in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:834:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Hvala vam svima na veoma brzom odgovoru (iskren da budem, nisam se nadao da ce biti ovoliko kvalitetnih odgovora i predloga).</p>\\n<p>Sada imam jos jedno pitanje; prijatelj kome radim instalaciju sprata je cuo da je FID-ova sklopka samo problem i da bi on da je izbjegne. Posto sam ipak i neko strucno lice (doduse sa ne tolikim iskustvom u ovom polju), mislio sam da mu predlozim da sve osim frizidera i zamrzivaca ide preko FID-ove sklopke in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:80992558b2955898862555685a0ddd9d'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', � in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:390:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Može imati mnogo veći problem ako je ne stavi.<br />\\nSa strujom nikad dosta zaštita.</p>\\n ', created = 1748726714, expire = 1748813114, headers = '', serialized = 0 WHERE cid = '3:80992558b2955898862555685a0ddd9d'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}', 3, '& in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:9ceb41dfad421bcc4c85769765701878'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', � in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:436:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Ma znam samo pitam da li je uobicajeno da se recimo zamrzivac ostavi da ne ide preko FID sklopke? Iz vaseg iskustva?</p>\\n<p>oto</p>\\n ', created = 1748726714, expire = 1748813114, headers = '', serialized = 0 WHERE cid = '3:9ceb41dfad421bcc4c85769765701878'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\&q in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:85fb43715192650fef305e649f16b725'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', � in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:975:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>A mudrolijat možeš kako hoćeš...sve ide preko FID sklopke zato što ona jedino štiti čovjeka , a osigurači kabele...ko ti j egod rekao da FID pravi probleme bježi od njega koliko te god noge nose..nikakav ti je to majstor..ja imam 40/0.5 A FID i nikad ali baš nikad lažno nije okinuo...toliko o tome, e sad ako atavljaš FID na staru nulovanu instalaciju e tu može bit problema dok se ne dovede FID u stanje da može raditi, zbog nulovanja po kutijama ,utič in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:71d3b00780f457d26cd1f9da6bf72a3b'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', � in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:507:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Stvar ima smisla : ukoliko \\'okine\\' FID-ova sklopka, zamrzivac ostane i dalje da radi, tako da ukoliko ljudi ne borave u kuci na duze vrijeme, to im osigurava da im se zamrzivac nece otopiti, zar ne ?</p>\\n ', created = 1748726714, expire = 1748813114, headers = '', serialized = 0 WHERE cid = '3:71d3b00780f457d26cd1f9da6bf72a3b'\";s:5:\"%file\";s:76:\"/home/admin/dom in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:c94419e0d7d4c8a52000e49a623f0f96'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', � in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:614:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Ja sam kod sebe izveo posebnu utičnicu za tu namenu kad sam na godišnjem odmoru da napajanje ide mimo FID zaštite, slažem se u potpunosti sa svim što je madmaxx31 napisao, ali se desilo da mi je jednom FID izbacio prilikom jake grmljavine i zbog toga sam izveo takvu varijantu i to samo za zamrzivač i frižider.</p>\\n ', created = 1748726714, expire = 1748813114, headers = '', serialized = 0 WHERE cid = '3:c944 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:c3ee51b1b65f311f8e9fbc9914a606b3'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', � in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:2827:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p><div class=\\"bb-quote\\"><b>otto wrote:</b><blockquote class=\\"bb-quote-body\\">Pozdrav svima,</blockquote></div></p>\\n<p>Novi sam na ovom forumu i mnogo mi je koristio, dok sam iscitavao pojedine teme...<br />\\nS obzirom da i ja pomalo radim instalacije, sta mislite , da li sam pogrijesio sto sam do k in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:7737bb98d1272be092a5817c2bd92f4c'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', � in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:637:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Ako svetlo na plafonu,ventilator i svetlo iznad ogledala ne stavljaš na isti osigurač kako ih u tabli rasporediš? Moraju doći na neku fazu. Ako si već doveo posebne strujne krugove za bojler,grejalicu i veš mašinu možeš im dodati i ove male potrošače i tako ćeš to uraditi u tabli pa zašto onda dovoditi još jedan kabel 5x1.5?</p>\\n ', created = 1748726714, expire = 1748813114, headers = '', serialized = 0 WHERE in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:24fe93111fba350d3aa14e1af45838d6'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', � in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1127:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>U svakom slučaju ako i napraviš tako kako si napravio nećeš ni u čemu pogriješiti..NAPOMENA ZA SVE: kabeli se stavljaju prema opterećenju koje će da podnose, nema greške ni ovako kako si napravio, ali po PS-u jeste 3*2.5 za bojler, grijalicu i veš mašinu(mada može i 3*1.5mm2 za sve od ovoga, do 4KW opterećenja je 3*1.5mm2) i 3*1.5 za rasvetu, radim godinama i vidio sam svašta, vjeruj mi na rječ ako je sve dobro i kvalitetno spojeno nećeš imati nika in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:8c237f5ae02e3d95272b4e373783108b'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', � in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:407:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Medonja ,</p>\\n<p>Veoma sam ti zahvalan na ovim savjetima!!<br />\\nPozdrav,<br />\\nOtto</p>\\n ', created = 1748726714, expire = 1748813114, headers = '', serialized = 0 WHERE cid = '3:8c237f5ae02e3d95272b4e373783108b'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\& in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:e0f06fc6dba147f5b728325808d7d181'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', � in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:396:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Madmax,</p>\\n<p>Nismo mogli da nadjemo tu sklopku, vec 40 A 0.5, sta mislis je li to OK?</p>\\n ', created = 1748726714, expire = 1748813114, headers = '', serialized = 0 WHERE cid = '3:e0f06fc6dba147f5b728325808d7d181'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;} in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:02377890d0028b022bfec8be1be1b20f'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', � in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:3444:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p><div class=\\"bb-quote\\"><b>svetleći wrote:</b><blockquote class=\\"bb-quote-body\\">Ako svetlo na plafonu,ventilator i svetlo iznad ogledala ne stavljaš na isti osigurač kako ih u tabli rasporediš? Moraju doći na neku fazu. Ako si već doveo posebne strujne krugove za bojler,grejalicu i veš mašinu možeš im dodati i ove male potrošače i tako ćeš to uraditi u ta in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:53428f74becd082ecc7a94d2d376e986'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', � in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:723:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p><div class=\\"bb-quote\\"><b>otto wrote:</b><blockquote class=\\"bb-quote-body\\">Madmax,</blockquote></div></p>\\n<p>Nismo mogli da nadjemo tu sklopku, vec 40 A 0.5, sta mislis je li to OK?<br />\\nHmmm..kako nisi evo ja imam dvije u ruci od KOPPA i od HAGERA 40/0.03, ta od 40/0.5 je za kompl.stan a ova za in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:abfecc63f09f063c306e2753273f32e4'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', � in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:942:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = '<p><iframe id=\\'a431a3a0\\' name=\\'a431a3a0\\' src=\\'https://adserver.samsvojmajstor.com/adserver/www/delivery/afr.php?zoneid=26&cb=9900435235423422\\' frameborder=\\'0\\' scrolling=\\'no\\' width=\\'728\\' height=\\'90\\'><a href=https://adserver.samsvojmajstor.com/adserver/www/delivery/ck.php?n=afcbc006&cb=9900435235423422\\&#0 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:19fe8dbf11d573b5bff835ce9a54f312'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', � in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:694:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Portal za sve ljubitelje majstorija, ručnih radova i ljude spretnih ruku. Ovde možete razmeniti iskustva, znanja i podatke o sitnim ili krupnim majstorskim radovima, u kući na radnom mestu, u bašti i i naučiti neku novu veštinu i pomoći vašem usavršavanju, a znanje i iskustvo doprineti bogatstvu ovog foruma.</p>\\n<p>Želimo Vam puno mašte i ugodan boravak na našem portalu.</p>\\n ', created = 1748726714, in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:ca011fdebe3a51dea5859d4aba19f564'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/elektroinstalacije/kabeli-optere%C4%87enje', � in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:956:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = '<p><iframe id=\\'a354bc39\\' name=\\'a354bc39\\' src=\\'https://adserver.samsvojmajstor.com/adserver/www/delivery/afr.php?zoneid=27&cb=002874370149734552\\' frameborder=\\'0\\' scrolling=\\'no\\' width=\\'234\\' height=\\'160\\'><a href=\\'https://adserver.samsvojmajstor.com/adserver/www/delivery/ck.php?n=aa83fdd3&cb=0028743701 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Kabeli opterećenje
Kabeli opterećenje
