Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:d46c1e4a22e69ba5916f4ac4459fe727'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/bravarija/drveni-%C5%A1aloni-%C5%A1kure%C5%BEaluzine-na-aluminijumsku-stolariju', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/bravarija/d in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:444:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Stavio bih obicne drvene šalone (škure,žaluzine) na aluminijumsku stolariju. Da li je problem montrati nosače bočno na zid?<br />\\nHvala</p>\\n ', created = 1764326935, expire = 1764413335, headers = '', serialized = 0 WHERE cid = '1:d46c1e4a22e69ba5916f4ac4459fe727'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/incl in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:299cf1094cfc902717dcf397eef122d8'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/bravarija/drveni-%C5%A1aloni-%C5%A1kure%C5%BEaluzine-na-aluminijumsku-stolariju', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/bravarija/d in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:468:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Зависи од зида, од чега је направљен, ако су блокови може да буде проблем или још горе стиропор.</p>\\n ', created = 1764326935, expire = 1764413335, headers = '', serialized = 0 WHERE cid = '1:299cf1094cfc902717dcf397eef122d8'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_h in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:311635b68c9f5be8fad38f70a9f701f7'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/bravarija/drveni-%C5%A1aloni-%C5%A1kure%C5%BEaluzine-na-aluminijumsku-stolariju', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/bravarija/d in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:541:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>[marq=left]<span style=\\"color:blue\\"><span style=\\"font-weight:bold\\"><span style=\\"font-style:italic\\">Uradi sam, ali bez znanja i alata nema zanata!</span></span></span>[/marq]</p>\\n ', created = 1764326935, expire = 1764413335, headers = '', serialized = 0 WHERE in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:f0da8a98e1c6682beb3cd064732e4fc0'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/bravarija/drveni-%C5%A1aloni-%C5%A1kure%C5%BEaluzine-na-aluminijumsku-stolariju', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/bravarija/d in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:409:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Без алата нема заната, a без знања ни најбољи алат неће помоћи..</p>\\n ', created = 1764326935, expire = 1764413335, headers = '', serialized = 0 WHERE cid = '3:f0da8a98e1c6682beb3cd064732e4fc0'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\" in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:3d1d73c5d6e68857a0bfcf3d175296fe'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/bravarija/drveni-%C5%A1aloni-%C5%A1kure%C5%BEaluzine-na-aluminijumsku-stolariju', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/bravarija/d in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:347:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Mislim da je cigla blok . Nema stiropora/stirodura.</p>\\n ', created = 1764326935, expire = 1764413335, headers = '', serialized = 0 WHERE cid = '1:3d1d73c5d6e68857a0bfcf3d175296fe'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}', 3, '', 'http://www.samsvojmajs in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:96d83a2d67996d49e07ec0bf2826622b'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/bravarija/drveni-%C5%A1aloni-%C5%A1kure%C5%BEaluzine-na-aluminijumsku-stolariju', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/bravarija/d in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1177:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Sve zavisi od toga koji okov kapaka će biti korišćen.<br />\\nKoliko je stolarija duboko postavljena odnosno koliko je udaljena u odnosu na ravan fasade?<br />\\nZamenio sam prozore/vrata uoči postavljanja izolacije, postavio sam ih na ivicu stare fasade i izašlo je je da je stolarija nekih 12 cm duboko u odnosu na ravan nove fasade. Okov kapaka mi dozvoljava max. 8 cm dubine a i estetski sve dublje od 5-7 cm je po in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:979c1eb897bfebc791fefddfb55f2547'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/bravarija/drveni-%C5%A1aloni-%C5%A1kure%C5%BEaluzine-na-aluminijumsku-stolariju', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/bravarija/d in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:342:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Nisam dovoljno bogat da kupujem jeftine stvari</p>\\n ', created = 1764326936, expire = 1764413336, headers = '', serialized = 0 WHERE cid = '1:979c1eb897bfebc791fefddfb55f2547'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}', 3, '', 'http://www.samsvojmajstor.c in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:979c1eb897bfebc791fefddfb55f2547'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/bravarija/drveni-%C5%A1aloni-%C5%A1kure%C5%BEaluzine-na-aluminijumsku-stolariju', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/bravarija/d in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:342:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Nisam dovoljno bogat da kupujem jeftine stvari</p>\\n ', created = 1764326936, expire = 1764413336, headers = '', serialized = 0 WHERE cid = '3:979c1eb897bfebc791fefddfb55f2547'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}', 3, '', 'http://www.samsvojmajstor.c in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:abfecc63f09f063c306e2753273f32e4'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/bravarija/drveni-%C5%A1aloni-%C5%A1kure%C5%BEaluzine-na-aluminijumsku-stolariju', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/bravarija/d in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:19fe8dbf11d573b5bff835ce9a54f312'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/bravarija/drveni-%C5%A1aloni-%C5%A1kure%C5%BEaluzine-na-aluminijumsku-stolariju', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/bravarija/d in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:ca011fdebe3a51dea5859d4aba19f564'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/bravarija/drveni-%C5%A1aloni-%C5%A1kure%C5%BEaluzine-na-aluminijumsku-stolariju', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/bravarija/d in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
drveni šaloni (škure,žaluzine) na aluminijumsku stolariju
