Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:a6241d1880ef45a480220b2b22c5657f'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/ku%C4%87na-tehnika/ves-masina-gorenje-wa61061', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/ku%C4%87na-tehnika/ves-masina-gorenje-wa61061', '172 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:727:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Pozdrav, imam veliki problem sa masinom Gorenje WA61061, radi u svim programima do 40 stepeni, na ostalim ne radi.<br />\\nGrijac radi ali grije samo do 40 stepeni. Dio koji omogucava da se utikac moze utaci u bilo kom polozaju (da nije bitan raspored faze i nule) je pregorio i vec duze vrijeme je masina radila bez tog dijela, znaci direktno spojena. Zna li ko sta bi to moglo biti? Dali moze biti termostat ili programator?</p>\\n &#03 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:f9c9fbf11f04fd32cf7c6bc5c7b15641'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/ku%C4%87na-tehnika/ves-masina-gorenje-wa61061', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/ku%C4%87na-tehnika/ves-masina-gorenje-wa61061', '172 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:411:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Za početak namontirajte, ili još bolje, neka Vam neko namontira, utikač sa uzemljenjem, pa da pričamo dalje...</p>\\n ', created = 1748741966, expire = 1748828366, headers = '', serialized = 0 WHERE cid = '1:f9c9fbf11f04fd32cf7c6bc5c7b15641'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}' in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:621fdb783583e711bfe5964a7a186a32'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/ku%C4%87na-tehnika/ves-masina-gorenje-wa61061', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/ku%C4%87na-tehnika/ves-masina-gorenje-wa61061', '172 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:343:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Genijalac je samo nik, nije karakterna osobina!</p>\\n ', created = 1748741966, expire = 1748828366, headers = '', serialized = 0 WHERE cid = '3:621fdb783583e711bfe5964a7a186a32'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/ in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:85f34b729277c13dd0163afa6032e1c7'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/ku%C4%87na-tehnika/ves-masina-gorenje-wa61061', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/ku%C4%87na-tehnika/ves-masina-gorenje-wa61061', '172 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:631:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Морам да приупитам на овој теми пошто је веш машина баш тај модел. Недавно је веш машина почела да се чује јако чудно, кад јој се укључи центрифуга почне некако као да гребе и да бруји ...</p>\\n ', created = 1748741966, expire = 1748828366, headers = '', serialized = 0 WHERE cid = in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:ea1ea1d51d4c4edb05703f2052b05b34'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/ku%C4%87na-tehnika/ves-masina-gorenje-wa61061', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/ku%C4%87na-tehnika/ves-masina-gorenje-wa61061', '172 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:835:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p><div class=\\"bb-quote\\"><b>dr.srb.91 wrote:</b><blockquote class=\\"bb-quote-body\\">Морам да приупитам на овој теми пошто је веш машина баш тај модел. Недавно је веш машина почела да се чује јако чудно, кад јој се укључи центрифуга почне некако � in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:d65d4314dfb805c23375e759f055776d'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/ku%C4%87na-tehnika/ves-masina-gorenje-wa61061', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/ku%C4%87na-tehnika/ves-masina-gorenje-wa61061', '172 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:372:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Јел може бити нешто озбиљно поводом тога ?</p>\\n ', created = 1748741966, expire = 1748828366, headers = '', serialized = 0 WHERE cid = '1:d65d4314dfb805c23375e759f055776d'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}', 3, '', 'http://www.sam in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:12e902d2928892d54a02cc62d324774f'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/ku%C4%87na-tehnika/ves-masina-gorenje-wa61061', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/ku%C4%87na-tehnika/ves-masina-gorenje-wa61061', '172 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1306:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p><div class=\\"bb-quote\\"><b>dr.srb.91 wrote:</b><blockquote class=\\"bb-quote-body\\">Јел може бити нешто озбиљно поводом тога ?</blockquote></div></p>\\n<p>Ako sam u pravu ( ovako na slepo) , znaci da nesto od ta dva odlazi.<br />\\nAmortizeri su oko 500-600 kinti/kom al in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:58d626a4fb13b85602396109e14dbb69'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/ku%C4%87na-tehnika/ves-masina-gorenje-wa61061', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/ku%C4%87na-tehnika/ves-masina-gorenje-wa61061', '172 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:455:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Ово друго би било да је упитању, пошто не вибрира само јако бруји и као да о нешто чеше ...</p>\\n ', created = 1748741966, expire = 1748828366, headers = '', serialized = 0 WHERE cid = '1:58d626a4fb13b85602396109e14dbb69'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\ in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:abfecc63f09f063c306e2753273f32e4'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/ku%C4%87na-tehnika/ves-masina-gorenje-wa61061', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/ku%C4%87na-tehnika/ves-masina-gorenje-wa61061', '172 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:942:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = '<p><iframe id=\\'a431a3a0\\' name=\\'a431a3a0\\' src=\\'https://adserver.samsvojmajstor.com/adserver/www/delivery/afr.php?zoneid=26&cb=9900435235423422\\' frameborder=\\'0\\' scrolling=\\'no\\' width=\\'728\\' height=\\'90\\'><a href=https://adserver.samsvojmajstor.com/adserver/www/delivery/ck.php?n=afcbc006&cb=9900435235423422\\&#0 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:19fe8dbf11d573b5bff835ce9a54f312'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/ku%C4%87na-tehnika/ves-masina-gorenje-wa61061', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/ku%C4%87na-tehnika/ves-masina-gorenje-wa61061', '172 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:694:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Portal za sve ljubitelje majstorija, ručnih radova i ljude spretnih ruku. Ovde možete razmeniti iskustva, znanja i podatke o sitnim ili krupnim majstorskim radovima, u kući na radnom mestu, u bašti i i naučiti neku novu veštinu i pomoći vašem usavršavanju, a znanje i iskustvo doprineti bogatstvu ovog foruma.</p>\\n<p>Želimo Vam puno mašte i ugodan boravak na našem portalu.</p>\\n ', created = 1748741966, in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:ca011fdebe3a51dea5859d4aba19f564'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/ku%C4%87na-tehnika/ves-masina-gorenje-wa61061', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/ku%C4%87na-tehnika/ves-masina-gorenje-wa61061', '172 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:956:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = '<p><iframe id=\\'a354bc39\\' name=\\'a354bc39\\' src=\\'https://adserver.samsvojmajstor.com/adserver/www/delivery/afr.php?zoneid=27&cb=002874370149734552\\' frameborder=\\'0\\' scrolling=\\'no\\' width=\\'234\\' height=\\'160\\'><a href=\\'https://adserver.samsvojmajstor.com/adserver/www/delivery/ck.php?n=aa83fdd3&cb=0028743701 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Ves masina Gorenje WA61061
