Trazio sam po forumu da vidim dal je neko nesto odgovorio na temu al je nisam mogao naci, ne znam dal je obrisana ili ne radi search.
Zanima me dal neko zna da postoji kod nas proizvod slican "duratex"-u ? To je nekakva farba koja bi trebala biti slicna tolexu. vise informacija ovde : http://www.acrytech.com/store.asp?pid=14119&catid=19771 [1]
Colors and Finishes
Durabak
Durabak is our standard topcoat we offer to finish cabs with. Durabak is an extremely tough, rubberized, polyurethane-based coating. Attractive and functional, Durabak is glossy and has a lightly textured surface (similar to tolex)
Kabinet uradjen duratexom : http://srforums.prosoundweb.com/index.php/fa/3407/0/ [2]
Izrada High-end studijskih monitora uz upotrebu duratexa : http://www.avsforum.com/avs-vb/showthread.php?t=927779 [3]
I just painted my BS-212's with Acrytech Duratex.
I used a hand roller for the first coat, and a textrured foam roller for the second coat.
The stuff has the consistancy of Jello Pudding, and smells just like art Acrylic Paints for Painters or, siliconized acrylic caulking.
http://srforums.prosoundweb.com/index.php/fa/3484/0/ [4]
Heres a close up you can sorta see the texture, though it was hard for me to disguise the wood patterns from my oh so soft Marine Grade Ply, Even after Heavy sanding. Though you can't tell from this shot.
http://srforums.prosoundweb.com/index.php/fa/3485/0/ [5]
Evo i slika jednog pojacala
[1] http://www.acrytech.com/store.asp?pid=14119&catid=19771
[2] http://srforums.prosoundweb.com/index.php/fa/3407/0/
[3] http://www.avsforum.com/avs-vb/showthread.php?t=927779
[4] http://srforums.prosoundweb.com/index.php/fa/3484/0/
[5] http://srforums.prosoundweb.com/index.php/fa/3485/0/
[6] http://www.samsvojmajstor.com/portal/forums/uradi-sam/obrada-drveta/duratex-durabak#comment-296735
[7] http://www.samsvojmajstor.com/portal/users/danko31
[8] http://www.samsvojmajstor.com/portal/forums/uradi-sam/obrada-drveta
Pozdrav!
Nisam siguran ali pokusaj sa body 950 ima u crnoj i sivoj varijanti,to je fora za zastitu auta od korozije.Posle mozes farbati u koji hoces boju.
