Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:fe0810b26a06ec7b8d02608c16e6016d'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/svetlo-sa-senzorom-pokreta-iznad-ulaznih-vrata-stana?page=28', '', '172.70.135.189', 1684449823) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:723:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Stan se nalazi u stambenoj zgradi. Iznad ulaznih vrata u stan u hodniku zgrade nalazi se sijalicno grlo na koje je stavljena obicna sijalica. E sad, ja bih hteo da tu sijalicu zamenim nekim osvetljenjem sa vec ugradjenim senzorom pokreta, a koje bi moglo da se namontira direktno na sijalicno grlo. Idealno bi bilo da to bude neka vrsta zidne lampe. Da li uopste postoji tako nesto? Ja nisam uspeo da nadjem nesto na internetu.</p>\\n & in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:3e766cb7b8bd667710c2b6a863336491'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/svetlo-sa-senzorom-pokreta-iznad-ulaznih-vrata-stana?page=28', '', '172.70.135.189', 1684449824) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:480:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Može da se postavi zidna lampa po izboru a senzor zasebno.Postoje samo sa halogenim sijalicama/reflektori/ i senzorom u kompletu.Senzor može da se kupi u svakoj prodavnici el.opreme.</p>\\n ', created = 1684449824, expire = 1684536224, headers = '', serialized = 0 WHERE cid = '1:3e766cb7b8bd667710c2b6a863336491'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor. in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:43e45fc258b3872715db711754470ff8'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/svetlo-sa-senzorom-pokreta-iznad-ulaznih-vrata-stana?page=28', '', '172.70.135.189', 1684449824) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:838:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Hmm.. ipak sam uspeo u medjuvremenu da \\"iskopam\\" nesto. Ovde ima veliki izbor zidnih lampi sa senzorom. Ovo je, ako se ne varam, sve u jednom. Dakle i lampa i senzor u jednom. Ne znam zasto bih posebno kupovao senzor ako postoje lampe sa vec ugradjenim senzorom!? Problem je sto mi ovi deluju kao neka fantomska firma, ali to nije ni bitno. Ocito postoji veliki izbor tih lampi koje meni trebaju samo nikako da pronadjem sajt neke in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:9d6d801ed1008199412383774aa1d0e6'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/svetlo-sa-senzorom-pokreta-iznad-ulaznih-vrata-stana?page=28', '', '172.70.135.189', 1684449824) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:614:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Zaboravih na link;</p>\\n<p><a href=\\"http://www.lampelusteri.rs/20-Spoljasnja-rasveta/3566-Senzorne-lampe.html\\" title=\\"http://www.lampelusteri.rs/20-Spoljasnja-rasveta/3566-Senzorne-lampe.html\\">http://www.lampelusteri.rs/20-Spoljasnja-rasveta/3566-Senzorne-lampe.html</a></p>\\n ', created = 1684449824, expire = 1684536224, heade in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:0610579eb4799c9d35395672c7725138'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/svetlo-sa-senzorom-pokreta-iznad-ulaznih-vrata-stana?page=28', '', '172.70.135.189', 1684449824) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:448:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Obrati paznju na to koliki je saobracaj ispred vrata, ako se cesto pali i gasi, znaju da crkavaju halogenke, a nisu jeftine da se mijenjaju svakodnevno.</p>\\n ', created = 1684449824, expire = 1684536224, headers = '', serialized = 0 WHERE cid = '1:0610579eb4799c9d35395672c7725138'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/ in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:9226a306017a3d7949a16165cada527c'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/svetlo-sa-senzorom-pokreta-iznad-ulaznih-vrata-stana?page=28', '', '172.70.135.189', 1684449824) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:694:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Ok. Kapiram. Ono sto mi nije jasno je to da nema sanse da nadjem adresu neke radnje u koju moze fizicki da se udje i da se kupi neka zidna lampa sa senzorom. Prosto ne mogu da verujem da i na ono malo sajtova na koje naletim usput, prodaja se vrsi iskljucivo preko interneta. Proveo sam brat bratu jedno tri sata trazeci po internetu. Kao da trazim iglu u plastu sena a ne obicnu lampu sa senzorom.</p>\\n ', created = 1684449824, in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:abfecc63f09f063c306e2753273f32e4'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/svetlo-sa-senzorom-pokreta-iznad-ulaznih-vrata-stana?page=28', '', '172.70.135.189', 1684449824) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:ca011fdebe3a51dea5859d4aba19f564'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/svetlo-sa-senzorom-pokreta-iznad-ulaznih-vrata-stana?page=28', '', '172.70.135.189', 1684449824) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:64a277481435f3c6a7b18eb6fa57f957'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/svetlo-sa-senzorom-pokreta-iznad-ulaznih-vrata-stana?page=28', '', '172.70.135.189', 1684449824) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:868:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = '<p><iframe id=\\'a694a55c\\' name=\\'a694a55c\\' src=\\'https://nepremicnine.click/www/delivery/afr.php?zoneid=99&cb=43241234\\' frameborder=\\'0\\' scrolling=\\'no\\' width=\\'300\\' height=\\'600\\'><a href=\\'https://nepremicnine.click/www/delivery/ck.php?n=a9f8f8a5&cb=63456\\' target=\\'_b in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Svetlo sa senzorom pokreta iznad ulaznih vrata stana | www.samsvojmajstor.com
