Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:7b42d343e201dcad24f578201b39c434'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/izolacije/betonski-panel-zid-kao-zvucna-izolacija-za-i-protiv?page=44', '', '172.70.39.71', 1684911968) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1284:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Hocu da postavim zid da bih smanjio buku koja dolazi od komsija. Video sam one panelne betonske ograde sa reljefima od cigle, kamena i slicno, ali jedino sto mi se nije svidelo je njihova debljina od 3-3,5 cm odokativno gledano. Uzljebljuju se u stubove 15x15. Zanima me da li cu dobiti nesto na zvucnoj izolaciji sa ovim zidovima, jeste tanko, ali je ipak beton, a beton je tezak. Svidja mi se sto se ovo moze postaviti za jedno popodne, stavio bih 2, in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:d8fd2f3ac97151a1cf26e175c8b41a70'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/izolacije/betonski-panel-zid-kao-zvucna-izolacija-za-i-protiv?page=44', '', '172.70.39.71', 1684911968) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:910:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Biće dobro rešenje, jer prepreka prostiranju zvučnih talasa mora biti masivna da ne počne i sama da se ponaša kao membrana koja osciluje.Još bi bilo dobro da je frontalna strana do izvora buke reljefna tako da reflektuje zvučne talase što više disperzivno.Takva rešenja se primenjuju duž autoputeva koji prolaze blizu naseljenih mesta, aerodromskih pista i na svim mestima gde buka ugrožava zdravlje žitelja.<br />\\nNapisano in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:311635b68c9f5be8fad38f70a9f701f7'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/izolacije/betonski-panel-zid-kao-zvucna-izolacija-za-i-protiv?page=44', '', '172.70.39.71', 1684911968) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:541:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>[marq=left]<span style=\\"color:blue\\"><span style=\\"font-weight:bold\\"><span style=\\"font-style:italic\\">Uradi sam, ali bez znanja i alata nema zanata!</span></span></span>[/marq]</p>\\n ', created = 1684911968, expire = 1684998368, headers = '', serialized = 0 WHERE in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:f0da8a98e1c6682beb3cd064732e4fc0'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/izolacije/betonski-panel-zid-kao-zvucna-izolacija-za-i-protiv?page=44', '', '172.70.39.71', 1684911968) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:409:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Без алата нема заната, a без знања ни најбољи алат неће помоћи..</p>\\n ', created = 1684911968, expire = 1684998368, headers = '', serialized = 0 WHERE cid = '3:f0da8a98e1c6682beb3cd064732e4fc0'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\" in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:236f1d6f930aaf7b3ee99f26ab79ab34'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/izolacije/betonski-panel-zid-kao-zvucna-izolacija-za-i-protiv?page=44', '', '172.70.39.71', 1684911968) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:767:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Kakvo crno potcenjivanje, od primitivnih komsija leka nema sem da se nekako izolujem, ili da vadimo svijetlo oruzje. Pokusavam da odradim ovu prvu varijantu, hvala na savetu, jedino sto me plasili je sto je zid samo 3cm, pa mi je delovao pretanko za zvucnu izolaciju. Kad nesto postavim stavljam fotke. Cena po metru je 18e, ofarbano 22e, sa prevozom. Za ugradnju ne znam, ali verovatno ce biti dovoljno skupo da cu ja preuzeti na sebe ugradnju i kopanj in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:f46618a7b40c80ce684050b22dc2933e'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/izolacije/betonski-panel-zid-kao-zvucna-izolacija-za-i-protiv?page=44', '', '172.70.39.71', 1684911968) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:581:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Pored tog zida mi je i metalna kapija za ulaz u garazu, kao i druga manja za pesacki ulaz. Sta mislite da na njih postavim deblji lim, kakav bi bio efekat? Mislim na lim 3 do 5mm, kakvu kombinaciju da napravim a da dobijem solidnu izolaciju, jer dzaba mi zid, ako i kapije ne izolujem.</p>\\n ', created = 1684911968, expire = 1684998368, headers = '', serialized = 0 WHERE cid = '1:f46618a7b40c80ce6840 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:28bb0167d4d727e66e812dd629bb49bd'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/izolacije/betonski-panel-zid-kao-zvucna-izolacija-za-i-protiv?page=44', '', '172.70.39.71', 1684911968) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:504:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Deblji lim neće biti dovoljno efikasan.Efektnije će biti da se na lim sa unutrašnje strane zalepi stirodur.Na taj način će se sprečiti efekat membrane, a težina kapije će biti samo neznatno povećana.</p>\\n ', created = 1684911968, expire = 1684998368, headers = '', serialized = 0 WHERE cid = '1:28bb0167d4d727e66e812dd629bb49bd'\";s:5:\"%file\";s:76:\"/home/admin in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:ffc6682b0e3de17144dcef4353af51bf'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/izolacije/betonski-panel-zid-kao-zvucna-izolacija-za-i-protiv?page=44', '', '172.70.39.71', 1684911968) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:391:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>@sciii, jesi li vec postavio ogradu, zanimaju me efekti zvucne izolacije takve betonske ograde?</p>\\n ', created = 1684911968, expire = 1684998368, headers = '', serialized = 0 WHERE cid = '1:ffc6682b0e3de17144dcef4353af51bf'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}', 3 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:abfecc63f09f063c306e2753273f32e4'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/izolacije/betonski-panel-zid-kao-zvucna-izolacija-za-i-protiv?page=44', '', '172.70.39.71', 1684911968) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:19fe8dbf11d573b5bff835ce9a54f312'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/izolacije/betonski-panel-zid-kao-zvucna-izolacija-za-i-protiv?page=44', '', '172.70.39.71', 1684911968) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:ca011fdebe3a51dea5859d4aba19f564'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/izolacije/betonski-panel-zid-kao-zvucna-izolacija-za-i-protiv?page=44', '', '172.70.39.71', 1684911968) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Betonski panel zid kao zvucna izolacija, za i protiv
