Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:8b5d412cf16942dd84c24e914f3781cf'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/izolacije/montiranje-zaluzina-posle-postavljene-izolacije-pomoc?page=42', '', '172.70.134.50', 1685181345) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:839:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Pozdrav svima.</p>\\n<p>Skoro sam postavio izolaciju na spoljasnje zidove (stiropor 10 cm). Sad su mi prozori ostali dublje u zidu, ukupno nekih 26 cm i zaluzine vise ne odgovaraju. Ne mogu da se otvore da nalegnu na zid..Prozori i zaluzine su trokrilni, drveni.. Kako da resim problem? Jedino mi pada na pamet drveni okvir oko prozora debljine 10 cm, pa onda zaluzine, ali nisam siguran kako ce to da izgleda. Da li neko zna in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:572d74d935933fc5c213466fdf2e9326'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/izolacije/montiranje-zaluzina-posle-postavljene-izolacije-pomoc?page=42', '', '172.70.134.50', 1685181345) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:449:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>kao što te žaluzine imaju nosač (letvu ) treba odraditi za svaku žaluzinu od 10cm bilo koji stolar ti to može odraditi ili ko ima stolarsku mašinu</p>\\n ', created = 1685181345, expire = 1685267745, headers = '', serialized = 0 WHERE cid = '1:572d74d935933fc5c213466fdf2e9326'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:cc8449f0c8a177a82b0ffe341bbb6963'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/izolacije/montiranje-zaluzina-posle-postavljene-izolacije-pomoc?page=42', '', '172.70.134.50', 1685181345) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:628:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p><a href=\\"http://kreativnost.4umer.com/\\" title=\\"http://kreativnost.4umer.com/\\">http://kreativnost.4umer.com/</a><br />\\n<a href=\\"http://perinedrangulije.multiply.com/\\" title=\\"http://perinedrangulije.multiply.com/\\">http://perinedrangulije.multiply.com/</a></p>\\n ', create in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:beab41f23fdcfd6225f2c361489aa1be'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/izolacije/montiranje-zaluzina-posle-postavljene-izolacije-pomoc?page=42', '', '172.70.134.50', 1685181345) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:601:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p><a href=\\"http://peradetlic.hupont.hu/\\" title=\\"http://peradetlic.hupont.hu/\\">http://peradetlic.hupont.hu/</a><br />\\n<a href=\\"http://kreativnost.4umer.com/\\" title=\\"http://kreativnost.4umer.com/\\">http://kreativnost.4umer.com/</a></p>\\n ', created = 1685181345, expire = 16 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:42657fa57247eac6d02e46ba3d9c2192'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/izolacije/montiranje-zaluzina-posle-postavljene-izolacije-pomoc?page=42', '', '172.70.134.50', 1685181345) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1471:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Radio sam izolaciju i zamenu stolarije 2010 godine. Nove prozore sam montirao na ivicu spoljnog zida i onda postavio izolaciju 10 cm malo /oko 2 cm/ preko prozorskog okvira. Onda sam napravio dodatni ram debljine 5 cm a koji je uzi i kraci od dimenzija prozorskog okvira za 4 cm / tu je onih po 2 cm sa svake strane/ i taj ram sam pricvrstio za prozorski okvir . Na taj ram su zalepljene samoljepljive lajsne sa mrezicom da bi se ostvario pravilan sp in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:979c1eb897bfebc791fefddfb55f2547'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/izolacije/montiranje-zaluzina-posle-postavljene-izolacije-pomoc?page=42', '', '172.70.134.50', 1685181345) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:342:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Nisam dovoljno bogat da kupujem jeftine stvari</p>\\n ', created = 1685181345, expire = 1685267745, headers = '', serialized = 0 WHERE cid = '1:979c1eb897bfebc791fefddfb55f2547'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}', 3, '', 'http://www.samsvojmajstor.c in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:979c1eb897bfebc791fefddfb55f2547'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/izolacije/montiranje-zaluzina-posle-postavljene-izolacije-pomoc?page=42', '', '172.70.134.50', 1685181345) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:342:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Nisam dovoljno bogat da kupujem jeftine stvari</p>\\n ', created = 1685181345, expire = 1685267745, headers = '', serialized = 0 WHERE cid = '3:979c1eb897bfebc791fefddfb55f2547'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}', 3, '', 'http://www.samsvojmajstor.c in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:e2c84d56208f99065363b5bc8dfc35af'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/izolacije/montiranje-zaluzina-posle-postavljene-izolacije-pomoc?page=42', '', '172.70.134.50', 1685181346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:323:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Pomogli ste mi. Zahvaljujem</p>\\n ', created = 1685181346, expire = 1685267746, headers = '', serialized = 0 WHERE cid = '1:e2c84d56208f99065363b5bc8dfc35af'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/for in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:abfecc63f09f063c306e2753273f32e4'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/izolacije/montiranje-zaluzina-posle-postavljene-izolacije-pomoc?page=42', '', '172.70.134.50', 1685181346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:19fe8dbf11d573b5bff835ce9a54f312'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/izolacije/montiranje-zaluzina-posle-postavljene-izolacije-pomoc?page=42', '', '172.70.134.50', 1685181346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:ca011fdebe3a51dea5859d4aba19f564'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/izolacije/montiranje-zaluzina-posle-postavljene-izolacije-pomoc?page=42', '', '172.70.134.50', 1685181346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Montiranje zaluzina posle postavljene izolacije. Pomoc
