Neverovatno ali Google prevodilac "ne prevodi" makedonski jezik ni na jedan jezik?
Ako ga postavimo kao srpski ili neki drugi, prevodi bez problema???
Pa zar da prevodimo na engleski, kao da je Makedonija u Sibiru????
"hello
I would like to first asking for a suitable location for a pump or automatic hidropak north where it is best to set up and maybe even give it stands in the space of 1.6m to 1.7m in height from 55cm it would be the one that made KUĆICA higher up in the stands we KANISTER down a plan to build in paragraph i pumped, and i measured the dimensions of that passes under it. upper part to me is isolated from foam with 12cm set of 6 plus side hardboard and sheet metal on all sides, because PRIČA ZA ZAMRZAVANJE has still not been tested on temperaruri no a doubt that they will freeze since, in this I PLASTIČAN KANISTER tank of 1000 l which is isto takO the plate, but time will show.
This is KUĆICA SE NALAZI the cottage and it the height of 2.5m, or how much is the standard one floor a while vodovodot e 0 m OD at this level is no UDALJEN for 16-18m of tank.
Send me the first question is whether the pressure would be enough to just go for the already connected with a water postojeći rezervoar directly or must I use to pump water and if the space under rezervoar Since, we will is planned for that kind of pump to be, as the maximum height of što can be namesti something is 55cm to 60cm, whether it is to pump automatic or not, and what brand, etc., to sever the zainteresovan hidropak 8-phase would be no knap and writes that must pump to be put in places where it aired, and so on and this for me for now now now. Plus if one knows specifically how CENA does North hidropak 8-phase."
Mala pomoć, mada je verovatno sada još gore ali ko razume shvatiće - kako kaže naš narod.
Čisto da čovek dobije odgovor kad je na našem forumu.
Poznajem Severove pumpe bolje nego makedonski jezik i koliko sam shvatio problem je spakovati pumpu u određeni prostor ili se varam?Konkretno kod ovog hidropaka može pumpa sa motorom da se raskači sa boce i postavi bočno(povezani su gibljivim crevom) ako to nešto znači.
https://www.facebook.com/cepacizadrva1/ [4]
