Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:0179fc5a03edb2491eea0da998a7f546'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/alati/aparat-za-zavarivanje-tigwell-225-kon%C4%8Dar', '', '172.71.254.251', 1748687482) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1834:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Pozdrav svima na ovom zanimljivom forumu:-)</p>\\n<p>Zamolio bih, ako se nađe netko, ko ima el.šemu za ovaj stari aparat:<br />\\nTIGWELL 225 Rade Končar, g.1986.<br />\\nIli, gdje bih pronašao neki servis za info.</p>\\n<p>Dobio sam ga u veoma dobrom stanju, pa bih ga ponekad upotrebio za amaterski rad. Takav biser nije za bacanje <img src=\\"http://www.samsvojm in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:e85eab908bdc0838eca45cde0b1a68bb'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/alati/aparat-za-zavarivanje-tigwell-225-kon%C4%8Dar', '', '172.71.254.251', 1748687482) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1386:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Bar nesto uopsteno da ti olaksam,kada niko nece.Imas radnu struju sa kojom zavarujes,ako hoces da varis sa pulsacijom struje,radna struja je obicno gornja(jaca),a donju(slabiju)stelujes u odnosu na gornju.Mozes da stelujes duzinu toka celog ciklusa(pulsa) i posebno trajanje gornje i trajanje donje struje.<br />\\nPostoji i stelovanje porasta struje na radnu struju(kosa linija)tj.posebno stelovanje vremena za koliko ce pocetna struja da poraste na radn in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:b9958e6037780d253bfe10d84bcb26e3'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/alati/aparat-za-zavarivanje-tigwell-225-kon%C4%8Dar', '', '172.71.254.251', 1748687482) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:815:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>kemppi, hvala!</p>\\n<p>Sigurno, sve pomaže:-), nešto znam, ali trebam još informacija...</p>\\n<p>Za varenje sa elektrodama, znaći, postoji samo potenciometar gore levo?<br />\\nIznad prekidaća \\"elektrode/TIG\\".<br />\\nSve ispod tog prekidaća jeste za TIG.</p>\\n<p>Oni prikljućci levo dole su za vodno hladenje i Argon (sredina in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:3d60d2c0c61b9c1b05498bea1216c4dd'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/alati/aparat-za-zavarivanje-tigwell-225-kon%C4%8Dar', '', '172.71.254.251', 1748687482) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1595:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Mali je verovatno glavni prekidac,za ukljucivanje.Probaj ukljuci taj aparat u struju ,pa ces sam shvatiti,ne mogu napamet da desifrujem,bitno je da shvatis kako radi uopste tig aparat.Kao pocetniku pulsacija struje ti i ne treba,pa ili je iskljuci ili pojacaj donju struju na radnu.Za prohrom idu crvene volfram elektrode,dovoljne su 2.4mm i 1.6mm,njih uglavnom i prodaju,nabavi zicu 308l debljine 1.5-2mm i parcice prohroma.Jacina struje ide otprilike 30A po mm deblji in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:a766d7f9451b95baee04c6e76cea88c1'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/alati/aparat-za-zavarivanje-tigwell-225-kon%C4%8Dar', '', '172.71.254.251', 1748687482) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:788:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Danas je aparat otišao u servis na kontrolu, tako če biti sigurnije.<br />\\nOnda slijedi \\"šnelkurs\\" zavarivanja i polako dalje:-)<br />\\nZahvalujem kemppi, za informacije.</p>\\n<p>Inaće, tražim napred za elektrićnom šemom tog aparata.<br />\\nGdje su poslednji put (ili bilo kada) proizvodili aparata za zavarivanje Končar?<br />\\nU Zagrebu ne znaju ni in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:abfecc63f09f063c306e2753273f32e4'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/alati/aparat-za-zavarivanje-tigwell-225-kon%C4%8Dar', '', '172.71.254.251', 1748687482) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:942:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = '<p><iframe id=\\'a431a3a0\\' name=\\'a431a3a0\\' src=\\'https://adserver.samsvojmajstor.com/adserver/www/delivery/afr.php?zoneid=26&cb=9900435235423422\\' frameborder=\\'0\\' scrolling=\\'no\\' width=\\'728\\' height=\\'90\\'><a href=https://adserver.samsvojmajstor.com/adserver/www/delivery/ck.php?n=afcbc006&cb=9900435235423422\\&#0 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:19fe8dbf11d573b5bff835ce9a54f312'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/alati/aparat-za-zavarivanje-tigwell-225-kon%C4%8Dar', '', '172.71.254.251', 1748687482) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:694:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Portal za sve ljubitelje majstorija, ručnih radova i ljude spretnih ruku. Ovde možete razmeniti iskustva, znanja i podatke o sitnim ili krupnim majstorskim radovima, u kući na radnom mestu, u bašti i i naučiti neku novu veštinu i pomoći vašem usavršavanju, a znanje i iskustvo doprineti bogatstvu ovog foruma.</p>\\n<p>Želimo Vam puno mašte i ugodan boravak na našem portalu.</p>\\n ', created = 1748687482, in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:ca011fdebe3a51dea5859d4aba19f564'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/alati/aparat-za-zavarivanje-tigwell-225-kon%C4%8Dar', '', '172.71.254.251', 1748687482) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:956:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = '<p><iframe id=\\'a354bc39\\' name=\\'a354bc39\\' src=\\'https://adserver.samsvojmajstor.com/adserver/www/delivery/afr.php?zoneid=27&cb=002874370149734552\\' frameborder=\\'0\\' scrolling=\\'no\\' width=\\'234\\' height=\\'160\\'><a href=\\'https://adserver.samsvojmajstor.com/adserver/www/delivery/ck.php?n=aa83fdd3&cb=0028743701 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Aparat za zavarivanje TIGWELL 225 (Končar)
