Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired
query: INSERT INTO watchdog
(uid, type, message, variables, severity, link, location, referer, hostname, timestamp)
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:3bccaf9a7c77bda9010145c92f615060'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/elektronika/aku-li-ionske-baterije', '', '172.70.135.107', 1684885298) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:502:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>pozdrav svima.zanima me da u aku bateriju.nije vazna da li je ni-cd ili ni-mh ubacim li ionske uloske.kako to da izvedem.znam da je potrebno ubacivati elektroniku.ako ima neko da mi to strucno objasni.hvala</p>\\n ', created = 1684885298, expire = 1684971698, headers = '', serialized = 0 WHERE cid = '1:3bccaf9a7c77bda9010145c92f615060'\";s:5:\"%file\";s:76:\"/home/admin/d in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:1ffc86db312638276307923a570265dd'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/elektronika/aku-li-ionske-baterije', '', '172.70.135.107', 1684885298) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:849:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Možete staviti LiIon ćelije, ali Vam je neophodna elektronika koja upravlja punjenjem i pražnjenjem baterijskog paketa. Na 4.2V/cell treba prekine punjenje, isto tako na 3.0V/cell treba da prekine pražnjenje. Druga stvar je punjač kojim se puni takav paket, koji nije isti kao za NiCd i NiMH jer je način punjenja drugačiji. Sve u svemu cela akcija je skupa i komplikovana i za nas koji svakodnevno sklapamo baterijske pakete i zahteva mnogo stru in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:abfecc63f09f063c306e2753273f32e4'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/elektronika/aku-li-ionske-baterije', '', '172.70.135.107', 1684885298) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:942:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = '<p><iframe id=\\'a431a3a0\\' name=\\'a431a3a0\\' src=\\'https://adserver.samsvojmajstor.com/adserver/www/delivery/afr.php?zoneid=26&amp;cb=9900435235423422\\' frameborder=\\'0\\' scrolling=\\'no\\' width=\\'728\\' height=\\'90\\'><a href=https://adserver.samsvojmajstor.com/adserver/www/delivery/ck.php?n=afcbc006&amp;cb=99004352 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:19fe8dbf11d573b5bff835ce9a54f312'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/elektronika/aku-li-ionske-baterije', '', '172.70.135.107', 1684885298) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:694:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Portal za sve ljubitelje majstorija, ručnih radova i ljude spretnih ruku. Ovde možete razmeniti iskustva, znanja i podatke o sitnim ili krupnim majstorskim radovima, u kući na radnom mestu, u bašti i i naučiti neku novu veštinu i pomoći vašem usavršavanju, a znanje i iskustvo doprineti bogatstvu ovog foruma.</p>\\n<p>Želimo Vam puno mašte i ugodan boravak na našem portalu.</p>\\n ', crea in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:ca011fdebe3a51dea5859d4aba19f564'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/elektronika/aku-li-ionske-baterije', '', '172.70.135.107', 1684885298) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:956:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = '<p><iframe id=\\'a354bc39\\' name=\\'a354bc39\\' src=\\'https://adserver.samsvojmajstor.com/adserver/www/delivery/afr.php?zoneid=27&amp;cb=002874370149734552\\' frameborder=\\'0\\' scrolling=\\'no\\' width=\\'234\\' height=\\'160\\'><a href=\\'https://adserver.samsvojmajstor.com/adserver/www/delivery/ck.php?n=aa83fdd3& in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135 aku li ionske baterije
Možete staviti LiIon ćelije, ali Vam je neophodna elektronika koja upravlja punjenjem i pražnjenjem baterijskog paketa. Na 4.2V/cell treba prekine punjenje, isto tako na 3.0V/cell treba da prekine pražnjenje. Druga stvar je punjač kojim se puni takav paket, koji nije isti kao za NiCd i NiMH jer je način punjenja drugačiji. Sve u svemu cela akcija je skupa i komplikovana i za nas koji svakodnevno sklapamo baterijske pakete i zahteva mnogo stručnosti i veštine. Ne zaboravite temperaturni senzor na LiIon paketu da ne bi sve otišlo u vazduh.
