Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:a29e5916640d8b605a7bc1acd4bcbb2d'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/sam-svoj-majstor/trpezarijski-sto-od-starih-vrata', '', '172.70.42.237', 1684510992) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:835:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Cao ,</p>\\n<p>imam ideju da napravim trpezarijski sto od starih vrata preko kojih bi stavio staklo. Noge kakve zelim su ovakve <a href=\\"http://goo.gl/JYHeH9\\" title=\\"http://goo.gl/JYHeH9\\">http://goo.gl/JYHeH9</a> ili nesto sa klasicnim nogama. </p>\\n<p>Problem mi je sto ne znam kako da napravim drvene noge za njega, a da b in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:7e76923a700c64b06133992663aaf7dd'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/sam-svoj-majstor/trpezarijski-sto-od-starih-vrata', '', '172.70.42.237', 1684510992) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:694:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Koliko mogu da vidim sa slike te tvoje noge su su ustvari gredica 5x5 cm. To možeš da nađeš na svakom boljem stovarištu. Nebih savetovao da noge šrafiš direktno za sto već pre za okvir na koji ćeš odozgo da staviš i sama vrata. Malo je nezgodno davanje saveta ovako jer neznam ni kako stojiš sa alatom ni kako stojiš sa iskustvom. Ali ako rešiš da zagrizeš tu sam za savet. Pozdrav.</p>\\n ', created = 1684510992, in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:a85ca2ad621b81bb1cfdd70086ffd9bc'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/sam-svoj-majstor/trpezarijski-sto-od-starih-vrata', '', '172.70.42.237', 1684510992) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:347:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Što više znaš više vrediš, ali više i patiš.</p>\\n ', created = 1684510992, expire = 1684597392, headers = '', serialized = 0 WHERE cid = '1:a85ca2ad621b81bb1cfdd70086ffd9bc'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}', 3, '', 'http://www.samsvojmajs in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:abfecc63f09f063c306e2753273f32e4'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/sam-svoj-majstor/trpezarijski-sto-od-starih-vrata', '', '172.70.42.237', 1684510993) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:19fe8dbf11d573b5bff835ce9a54f312'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/sam-svoj-majstor/trpezarijski-sto-od-starih-vrata', '', '172.70.42.237', 1684510993) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:ca011fdebe3a51dea5859d4aba19f564'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/uradi-sam/sam-svoj-majstor/trpezarijski-sto-od-starih-vrata', '', '172.70.42.237', 1684510993) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Trpezarijski sto od starih vrata
