[1] http://www.samsvojmajstor.com/portal/forums/uredjenje-%C5%BEivotnog-prostora/kupatilo/odr%C5%BEavanje-hidromasa%C5%BEne-kade#comment-323074
[2] http://www.samsvojmajstor.com/portal/users/jasna
[3] http://www.samsvojmajstor.com/portal/forums/uredjenje-%C5%BEivotnog-prostora/kupatilo
Prati dezinfekcionim rastvorom?
Kad izguglas, dobijes:
Da biste vašu kadu održavali higijenski čistom (ukoliko nemate ugrađen sistem za dezinfekciju) preporučujemo vam naš dezinfekcioni rastvor koji se lako primenjuje: po mogućnosti nakon svakog kupanja, ali bar jednom mesečno sipati jedan do dva zatvarača (u zavisnosti od veličine kade) dezinfekcionog sredstva u kadu napunjenu čistom vodom i uključite sistem cca. 10min. Tada ispraznite kadu i sperite je čistom vodom pre sledeće upotrebe.
Whirlpool Maintenance: It is recommended that the circulation system be cleaned once every 2-3 weeks. There are several whirlpool tub cleaners available on the market. If a cleaner is not available, fill the tub with warm water, add 1 teaspoon of a mild dishwashing liquid and ½ cup bleach. Run the whirlpool system for several minutes. Drain and fill with cold water. Run the whirlpool system for five minutes. Drain.
Air Tub Maintenance: Air baths are equipped with an automatic blow drying function to eliminate excessive moisture from the channels after they shut off. This purges the system of all moisture.
