Skidanje mašine sa palete
Statičar ili geomehaničar...
Aspirator DIY - da li mož...
Curenje vode na sigurnosn...
Naslovna » Forums » Ručni radovi » Dekoracije i suveniri
DREAMCATCHERS - HVATACI SNOVA
28 poruka / 0 new
Thu, 02/12/2010 - 17:48
Aryan
Aryan's picture
Registrovan dana: 02/12/2010
  • 10069 prikaza
  • Dekoracije i suveniri
Thu, 02/12/2010 - 22:41
Re: par mojih radova...
Aryan
Aryan's picture
Aryan wrote:
Thu, 02/12/2010 - 22:44
Aryan
Aryan's picture
Aryan wrote:
Aryan wrote:
Thu, 02/12/2010 - 23:39
Aryan
Aryan's picture
Aryan wrote:
Aryan wrote:
Aryan wrote:
Thu, 02/12/2010 - 23:40
Aryan
Aryan's picture
Aryan wrote:
Aryan wrote:
Aryan wrote:
Aryan wrote:
Thu, 02/12/2010 - 23:41
Aryan
Aryan's picture
Aryan wrote:
Aryan wrote:
Aryan wrote:
Aryan wrote:
Aryan wrote:
Thu, 02/12/2010 - 23:42
Aryan
Aryan's picture
Aryan wrote:
Aryan wrote:
Aryan wrote:
Thu, 02/12/2010 - 23:44
Aryan
Aryan's picture
Aryan wrote:
Aryan wrote:
Thu, 02/12/2010 - 23:47
Aryan
Aryan's picture
Aryan wrote:
Fri, 03/12/2010 - 00:47
Re: DREAMCATCHERS - HVATACI SNOVA
pandora
pandora's picture
Registrovan dana: 25/10/2009
Hvatači snova su stvarno lepi (bez obzira da li neko veruje u to ili ne)
Fri, 03/12/2010 - 09:51
lepi jesu jako dobro i lepo izgledaju
još kad bi nam aryan kazao dal ih pravi ili samo reklamira
Fri, 03/12/2010 - 10:42
Aryan
Aryan's picture
Hvala Puno!
Ja ih pravim vec skoro 2 godine od raznih materijala od kojih su osnovni koza i perje naravno.
Iskren da budem u pocetku sam bio jako smotan posebno kada pletem mrezu Smile al sada je vec postala rutina da ide jako brzo i da dobro izgleda sve.
Ako imate jos nekih pitanja odgovorim Vam.
Lijep Pozdrav
Fri, 03/12/2010 - 11:27
koje perje jeli prirodno ili ga bojiš
Fri, 03/12/2010 - 12:15
Aryan
Aryan's picture
perja ima nabaviti u prodavnici chemaco u zagrebu tamo sam nabavljao , u norveskoj od prijatelja koji mi donio skalp fazana a zadnje vrijeme setam po prirodi i skupljam perje orlova jastreba sokola vrana patki Smile posto dreamcatcher puno prrirodnije izgleda sa prirodnim perima nego sa bojenim
Fri, 03/12/2010 - 18:09
Blabla
Blabla's picture
Registrovan dana: 20/02/2010
Hvatači snova...
Stvarno su prelepi. Koje su im dimenzije?
Sat, 04/12/2010 - 03:03
Aryan
Aryan's picture
Blabla wrote:
Hvatači snova...
Hvala Lijepa ! zavisi od dijametra 7 cm koji obicno dodju ko ukrasi u autu do 25 - 30 cm !
Sun, 12/12/2010 - 14:47
Aryan
Aryan's picture
Dreamcatchere izradjujem i po narudzbi i prodajem takodje pa ako ko ima zainteresovan slobodno se javi
Sun, 12/12/2010 - 19:09
prodaja ide preko pp ne ovako javno
nije fer prema onima koji plaćaju reklamu na sajtu
Sun, 12/12/2010 - 20:23
Aryan
Aryan's picture
Izvinjavam se nisam znao stvarno Sad oprostite Sad
Wed, 15/12/2010 - 13:28
creatino
creatino's picture
Registrovan dana: 03/09/2008
Da je lijepoooo -lijepo je...
a ajd me prosvetlite odakle ime ovom ukrasu,kakvo vjerovanje spominje pandora...malo me sramota biti neznalica al bolje jedan dan nego neznalica cijeli zivot. Hvala unapred, pozz
Wed, 15/12/2010 - 13:41
od američkih indijanaca
to je hvatač snova koji hvata ružne snove i ne dozvoljava da dođu do tebe
tako da ko to postavi kod sebe kući sanja samo lepe snove
Wed, 15/12/2010 - 13:48
pandora
pandora's picture
Nezamerite što sam ovo kopirala sa neta, jer je veoma lepo objašnjeno. Ja lično slabo verujem u te stvarčice ali ko zna što nešteti možda može i da koristi.
U mnogim plemenskim društvima širom svijeta vjerovalo se da je nocni zrak ispunjen lošim i dobrim snovima koji lete. Postojali su brojni nacini na koje su ljudi pokušavali da one lijepe dozovu u svoje snove. Indijanci su u te svrhe pravili hvatace snova. Obicaj je bio da se njima daruju novorodjena djeca i tek vjencani parovi. Indijanci imaju svoju legendu o hvatacima snova. Prije mnogo vremena, stari vrac iz plemena Lakota bio je na visokoj planini kada je dobio viziju. U toj viziji se Iktomi, veliki ucitelj mudrosti, pojavio u obliku pauka. Iktomi mu se obratio na svetom jeziku, a dok je govorio, uzeo je obruc od vrbe koji je imao na sebi konjsku dlaku i perle i bebe, prelazimo kroz djetinjstvo i odrastanje, do starosti kada se poceo da plete mrežu. Pricao je o ciklusima u životu - kako pocinjemo život kao ciklus završava. U svakom životnom dobu postoje mnoge sile, neke dobre, a neke loše. Ako slušate dobre sile, one ce vas usmjeravati u pravom smjeru. Kada je Iktomi završio pricu, dao je vracu mrežu i rekao da je mreža savršen krug sa rupom u sredini, te da treba da je iskoristi da njegovi ljudi pronadju svoje ciljeve, da na pravi nacin iskoriste svoje ideje, snove i vizije. Ako vjerujete, mreža ce uhvatiti vaše dobre ideje, a loše ce otici kroz rupu. Vrac je ovo prenio svom narodu i zato sada mnogi Indijanci kace hvatace snova iznad svojih kreveta. Dobro se hvata u mrežu života, a zlo propada kroz rupu u centru mreže i više nije dio njihovih života. Hvatac se postavlja pored prozora u spavacoj sobi; prema vjerovanju, u njegovu mrežu hvataju se snovi, od kojih samo oni dobri bivaju zapamceni. Dobri snovi, znajuci put, lebde kroz mrežu, cuvaju u sebi znanje i uspomene, zatim prolaze kroz centar i klize niz perca pravo do osobe koja sanja. Loši snovi se beznadežno upetljavaju u mrežu hvataca snova i izgore na prvoj svjetlosti dana. Hvataci snova ne moraju se koristiti samo u spavacim sobama, vec mogu biti amajlija u kolima, ili na ulazu u kucu. Prave se od alkica, manjih ili vecih perli; može se staviti i poneko perce, a mrežica je neophodna. Zato, ako vas muce ružni snovi, samo okacite hvataè snova iznad kreveta i lijepi snovi æe sami doæi. Laku noæ!
Wed, 15/12/2010 - 16:53
Aryan
Aryan's picture
Pandora ovo si jako lijepo napisala tj kopirala i ustvari to je ta indijanska legenda i uglavnom sva plemena imaju istu ili slicnu legendu, ja bih samo dodao da bi hvatac snova bio funkcionalan morali bi ocistiti bar dio prirode u kojem smo nasli pera ako ima smeca ili slicnih stvari i zamoliti " Majku Zemlju " da nam blagosiva hvatac snova , to mi je preporucio jedan prijatelj indijanac kojeg sam upoznao preko facebook.a, jer sam mu slao par slika koje sam i ovdje postavio Wink
Thu, 16/12/2010 - 13:25
creatino
creatino's picture
Hvala dragi drugari, osim sto lijepo izgledaju i prica o njima je takođe lijepa...hvala vam, pozz
Thu, 16/12/2010 - 14:32
Aryan
Aryan's picture
nema na cemu jako puno sam ih poklonio prijateljima i bliznjima strasno su kul kao pokloni
Wed, 04/06/2014 - 14:05
Zdravo svima.Interesuje me
elena86
elena86's picture
Registrovan dana: 04/06/2014
Zdravo svima.Interesuje me gde nabavljate perije
Wed, 04/06/2014 - 20:19
Većina pozamanterija ima
pandora
pandora's picture
Većina pozamanterija ima perija. Evo recimo čičak iz Niša ima neke šaleve od perija mislim da je 800 din 2 m, verovatno svaka veća pozamanterija u BG ih ima i na komad. Mada možeš da pronadješ nekog ko ima odgajivačnicu papagaja ili da očerupaš nekog petla.
Thu, 05/06/2014 - 00:06
To mi na kraju i jesta namera
elena86
elena86's picture
To mi na kraju i jesta namera ako ne nadjem odgovarajuce perije,da cupam zivinu .Inace iz manjeg mesta sam pa ovde nemam gde da ih nabavim,zato bi mi odgovaralo kada bih mogla da narucim negde ali neku vecu kolicinu za pristojnu cenu,jedino gde sam nasla su sajtovi za repromaterijal ali ima samo po 5 perca u pakovanju i to mi se ne isplati a i mala su mnogo.A te salove sa perjem sam vidjala kod mene ali mi je mnogo 2m perija u istoj boji ne znam sta cu sa njim posle.Bas sam zahtevna
