Uz malo "istrage " i pojavi se ovaj aparat . Definitivno ga rade kinezi i to bar 6-7 firmi tolko sam im'o zivaca da ispratim :tup :tup
Evo i crno na belo KINEZI [10]
A sad sve ostalo je na onom ko' oce da ga kupi :hh :hh
This excellent package includes both the Cobel AC / DC TIG Welder and a foot pedal that is designed especially for the Cobel TIG Welder.
There are TIG welders and there are inverter welders and there there is the Cobel 200AMP pulsed inverter TIG AC/DC welder!
The newly developed Cobel TIG200P AC/DC welder can weld stainless steel, alloy steel, carbon steel and other non-ferrous metals with the DC function and aluminum and alloy aluminium with the AC function.
The power exchange rate of this welding equipment is over 85% and is energy saving. With the exclusive HF Inverter technology this welder is smaller in size, lighter in weight, has a higher power exchange rate and is more energy efficient than other similar welders in the market.
The outstanding feature of this welder is the application of twice square eaves interveter technology, which allows pure square wave output.
This auction includes a dedicated foot pedal, making it simply an outstanding welder
Model TIG200P AC/DC
Power voltage 220V
Input frequency 50/60 Hz
Rated input current 20A
Power capacitance 4.5 KVA
Rated output current 200A
Range of output current 5-200A
Arc force 0-100A
No-load voltage 56V
Working voltage 18V
Pre-flow 0-2S
AC output frequency 60Hz
Clean width 20-80%
Slope-down time 0-10S
Post-flow time 0-10S
Base current 10-90%
Pulse frequency 0.5-300Hz
Pulse duty cycle 10-90%
Arc leading HF VIBRATION
Efficiency 85%
Load duty cycle 200A-60%
Power factor 0.93
Weight 20KG
Dimensions 493 x 330 x 320 mm
Max welding thickness 10mm
Imam ponudu za 860 a sluzio bi mi za neke tanje stvari u Al .Cenovno odgovara al ne znam moze li sve to sto pise.Miller mi je dao ponudu za nesto slicno oko 4000.S druge srane Gorenje?Radio sam s Gorenjem i nista posebno nekako ko kinezi al "ZNAS TO JE GORENJE"Jedan moj prijatelj mi kaze da je ova masina iskopirana od gorepomenute i radi mu evo druga godina u komercijalne svrhe.Ja ne hvalim ovaj aparat, samo pitam da li je neko radio s njim?
Vidi ako sam te dobro razumeo cena 860 E
To je ne previse skupo nego je to strasno i ne vredi te pare sigurno . Za te pare mozes naci Linkolna il nesto u toj klasi ( tig bez AL )
I ono sto je uvek problem sa kinezima su garancija i rezervni delovi
Ja ti kaz'o a i ti kako oces .
I da dodam jos jednu stvar kod kineske robe se uglavnom ispostavi da su karakteristike i performanse manje bar za 50 % od deklarisanih
Da,Linkolna sam imao i prodao zbog Al.Bio je oko 1000.Ni za njega nije lako naci deo ,ima al preko ako neces da platis jedno 5-6 provizija
Da nisam skeptican ne bih postavio pitanje ...ceka se neko sa iskustvom ako se javi.Inace cena mu je 1100 funti pa tome dodaj carinu i ostale takse.
Miller mi se jako svidja a Kempi posedujem
кад год су кинези у игри у вези било чега далеко им лепа кућа(нема смисла да псујем) :nono
Sta da kazem
Evo sad u online komunikaciji sa jednim kolegom iz Londona , on mi kaze da taj Cobel bas isti kosta oko 270 funti i to u radnji .
E sad za Linkolna sta da ti kazem delovi se kupuju u Bogradu i svega ima .
A usput u vezi Linkolna mogu da kazem da je jedino on radio na -49 stepeni
E sad sta reci ovo u vezi iskustva mozda sam i ja radio sa tim istim aparatom al nije bio pod imenom "Cobel " . Inace mi samo kuciste lici na jedan aparat s kojim sam radio /probao a ime mu je bilo Krant ako se dobro secam . I aparat je vrlo los . Ali opet je odluka na tebi .
Ne znam cime se tacno bavis , ali ako se bavis zavarivanjem profesionalno onda bi ti ipak trebao neki profi aparat a ne kineska igracka
A opet kazem na dosta zavarivackih foruma sam clan i svi imaju samo losa iskustva sa ovim " Cobelom " u stvari sa tim modelom bez obzira na robnu marku -nalepnicu na njemu
Hvala na trudu.Bavim se zavarivanjem oko 20 godina ali ne profesionalno vise kroz auto reparaturu,poceo acetilenom ko i svi u stvari vecina ,zaboravio sam da sam na bravarskom delu foruma.Acetilen pa mig ,pa tig .Tig je za mene kruna svega,cak me podseca na acetilen samo ima puuunnoooo sarenih dugmica i mozes svasta zato da uradis .to je vrhunac.svega.U Arc zavarivanju nisam bas jer sam uvek gledao da zavrsim migom.Ovih dana imao sam zadatak da napravim modifikovani rezervoar za svog dzipa pa tako potegoh aparat malo da varim aluminijum,pa dodje par ljudi pa poce rasprava pa ponuda za aparat a ja ko za svaku novu igracku oci mi zasjale. Inace trenutno sam u poslu oko auto lakiranja,zavrsio sam komoru secate se kad sam smarao gde da nadjem panele.
Dovoljno sam skrenuo s teme,
Hvala jos jednom
лепо за видети,али кинези........ :nono
Jedan majstor mi je pre nekih 6-7 meseci doneo nov takav aparat ali pod imenom "Greenbird" da bih ga malo obucio da radi na njemu. Aparat je kineski definitivno i imao je vrlo oskudno uputstvo na engleskom. Ko zna kako je dosao u Srbiju jer je bio nov ali nije imao ni racun ni garanciju niti postoji ovlasceni servis
Ono sto mi je odmah zasmetalo je da ima displej, ali je radio samo pri REL postupku. Kada se prekidac prebacio na TIG AC, na displeju se amperaza nije menjala. Da bi se na displeju ocitala amperaza pri TIG postupku bilo je potrebno prebaciti na REL, podesiti amperazu, pa tek onda prebaciti prekidac na AC TIG. Aparat ima los balans AC struje (ali ga ima), i zanimljivo da je inverzno podesen u odnosu na podesavanja kod evropskih aparata. Ne secam se onog, ali ovaj nema podesavanje AC frekvencije, vec mu je fixirana na 60 Hz, sto ga odmah svrstava u najnizu mogucu klasu AC TIG aparata.
Sama sekvenca je najprostija moguca.
Sto se ostalog tice, radio je OK, i majstor je kasnije sa tim aparatom radio cak i cevcice klima uredjaja na kolima i za svoje potrebe je bio zadovoljan.
Ako smatras TIG postupak krunom zavarivanja, onda kupi i TIG aparat barem iz srednje klase, mani se ovoga.
Jako sam zainteresovan za kupovinu nekog tig aparata pa bi mi trebala preporuka nekog provjerenog modela.Prvenstveno bi mi bio potreban za zavarivanje inoksa tj. ograda od inoksa iako se ne bih bunio da može zavariti i al.Int. me cjena nekog srednjeg modela mislim da mi više od 200 amp ne treba i na šta sve moram obratiti pažnju prilikom kupovine tj. koje su bitne činjenice.Sada imam fronius i wurth invertore ali sa mehaničkim ventilom i kontakt okidanjem koje povremeno koristim za manje stvari.
Pa ako Kemppi Master tig {Mls 2300} nije srednja klasa onda nek mi neko kaze sta jeste.Meni je sasvim ok ali da ponovim ovo mi se ucinilo simpaticnom igrackom.Poslusao sam Tenzora i od juce citam neke postove na raznim forumima Svetskim i svasta sam video,npr ovo http://www.weldingtipsandtricks.com/wasted-200-bucks-on-chinese-welder.html [27]
http://www.weldingtipsandtricks.com/no-homework-no-reason-to-complain.html [28]
Ima zadovoljnih i mnogo vise nezadovoljnih.,kao da je svaki komad drukciji.
Uopste mi nije zelja da ovo prosirim na veliku raspravu i pljuvanje po kinezima.to sam vec video u nekoj drugoj temi.pa ajd da se preselimo tamo.
Molim za Lock moderatora
Zašto zaključati temu, ako ljudi samo iznose svoje vidjenje, iskustva i mišljenje o nekom proizvodu.Ako je i pljuvanje po kinezima kako ti kažeš, ako su pametni pročitaće šta ljudi misle o njihovim jeftinim proizvodima pa će nešto preduzeti ako hoće da i dalje prodaju svoju robu na tržištu.Tako da i kritika može biti korisna, a ne samo pohvale i superlativi.
Temu sam poceo tako sto sam trazio iskustva majstora i onih koji se uce da to budu za konkretnu stvar a ne neko suvo teoretisanje tipa ja sam cuo ili rekla mi baba Stanojka......Kineze niti volim niti mrzim isto koliko i ostali prosecni konzumenti.Nema veze s temom ali ko od vas ne nosi ili nije nosio Nike patike proizvedene u Kini ....niko se ne zali i ne baca to u kantu sto je kinesko.Kinezi tako rade jer ne zele da kupe "know how"tehnologiju koju prodaju svetu visoko razvijene i demokratski orijentsane zemlje 1. sveta.To sto ti kupis Millera ili Lincolna ti platis vise od pola samo za Logo.ostalo je stvar relativno ista a da ne pominjem komponente iz fabrika iz Kine Indije ,Tajvana .Indonezije.Da nema tih pokusaja da se uzme deo kolaca na svetskom trzistu kojim neprikosloveno vladaju Veliki Esabi Fronijusi i ostali,cene nikad ne bi ni pale i mnogima od Nas-vas bi ostala samo puka zelja da zavare nesto u tigu.
Nista nije bolje ni u ostalom delu industrije.U automobile nam ugradjuju vise nego zastarele 8 bitne procesore u racunarima koje kao se pokvare naplacuju kao najnovije sa 4 jezgra .pa s tom tehnologijom je covek otisao na mesec!!!
Mercedesov agregat je i dalje tezak pola tone nasuprot agregatu iz Moje Honde koja ima 150 kg i 160 konja.No koji je za vecinu najbolji auto-Mecka zna se. Ko nije seo u Hondu ili Mozda Leksusa i dalje ce to tvrditi.
E zbog ove i ovakve verbalne masturbacije sam Zamolio moderatora da se tema zakljuca i preselimo se na drugu u kojoj je ovo i svrha!
факат је да нам кинези уваљују г.....а па се после хватамо за главу због делова и сервиса.принуђени смо на њихове производе под овим или оним именом.да је неког реда и ЈУС-а не би ни ноге смрделе након изувања њихових најки.пошто је пост офф слободно нека се брише али нисам могао да не кажем.....а ти купи апарат који можеш и желиш за своје новце :bye2
Znas sta me nervira:ima jedan u beogradu ili ti ovde koji kupuje od kineza u rifuzi pa to sklapa pa mu moj poznanik J....(ime cu reci na PM)radi plastifikaciju kucista pa to plasira ko proizvod domace pameti ,naravno daje i garanciju.E sad jel on kinezu kinez ili voli vise nas pa........
Ljudi ja stvarno necu kupiti tog konkretnog -IMAM Kemppi Koji je mozda kinez unutra ali ko zna.Evo idem sad na Bubanj potok mozda me tamo ceka neki Esab i sl
Evo ovako
na pameti mi je nesto drugo konsruktivnije:nikad nisam imao punkt aparat ali sam koristio jedan,imao je 3 deeebbbeeeellleeeee mase i nesto kao rukohvat od el lucnog aparata sa komadom bakra precnika 30tak mm.na njemu malo dugme a podesavanje na aparatu.E posto to stvarno nemam a treba mi mislio sam da uzmem trafo od el lucnog,skinem sekundar namotam jedno 4 namotaja .trba mi 3V 3000A,dodam vemenski rele....
Ajmo konsruktivne predloge!!!
Da se razumemo odma Demiane
Postavio si pitanje i dobio odgovor o tom modelu aparata . Ja sam u svakom tvom postu naveo da je odluka samo na tebi . Niti kudim kineze niti ih hvalim i sam imam mnogo alata koji je genericki kinez a ja ga opet koristim i profi svrhe i PREZADOVOLJAN sam . E sad ono sto mene najvise nervira su ovi nasi "uvoznici " koji te aparate nize klase prodaju po cenama onih iz vise i srednje klase . Konkretno ovaj "Cobel " u Kini kosta manje od 100 $ a ti rece dati je nudjen za 1000 E Pa uz to nema ni garantije a ni servisa .
Evo da ti objasnim odma . Da si ti pitao ovde da li da kupis taj aparat za 100 il 200 E, ja bi ti odma rekao KUPUJ . Jer kolko god da je los ima da radi bar 100 h i sam je sebe otplatio ihaj , a sve ostalo je cista dobit . Ali nazalost nije tako . I jos nesto u robne marke i kvalitet smem da se usudim da apsolutno hvalim nesto ako je to starije od 25 godina . Danas su druga vremena kalkulacija je bitna stavka , pa se cesto meni vise isplatida za godinu dana unistim na gradilistu 5 einhel brusilica nego jednu firmiranu , jel mi je tako jeftinije . A posto zivim od svog posla to mi je vrlo bitno . Evo recimo jedna solidna preporuka za Einhel BT-IW 160 (rel i tig inox) aparat u odnsou cena/kvalitet vise nego odlicna .
Bio danas na B potoku,nijedan brand name aparat.
Tenzore i dalje tvrdim da si u pravu,i ja akam one male zute Einhelove brusilice po 1000din i bacam ih posle iako bih imao pravo na garanciju.Mnogo su dobre.Cobel ,Mitac i druga imena su u Kini od 100-1000 dolara sve zavisi da li uzimas 5(minimum) ili 1000 kom.Za vece kol dobijas i podrsku.U Londonu je cobel 470 funti isto ja proverio.U USA je Riland napravio sebi mesto na trzistu sa respektom boreci se sa najvecima i cena im nije bas naivna.Ako ti znas nekog ko prodaje za 100-200-300-400-500 javi mi molim te bez obzira ima li garanciju(tzv garancija do kapije).I dalje cu vrlo postovati tvoje misljenje.i sad te molim za isto u vezi drugog dela mog poslednjeg posta na koji se nisi uoste osvrnuo.Molim te da konacno postanemo produktivni ili inovativni te stavimo na stranu razmisljanja o kinezima.Tu bih stavio jos jednu opasku o aparatima od pre 25 godina.Tad jos nisu izmislili pulsno zavarivanje ili jesu ali samo u Rozvelu.Nisam mlad al mi je nekako drazi novi tig.Zamisli zivot tj zavarivanje bez Mosfeta ,chopera .UUUU ne mogu ni da zamislm kolika bi to sprava bila u to vreme.Jos jednom te molim da mi ovo ne uzmes za zlo jer veoma cenim tvoje misljenje
Ma jok ne uzimam ti nista za zlo
Eto trenutno nemam bas ideju za neki TIG ( za Al ) a da mu je cena prihvatljiva
Ali da smo clanovi paypal-a sve bi mnogo lakse bilo . E -bay bi doneo veliko okasanje svima . Na primer ja sam preko Limunda kupio komplet nareznica REMS -EVA ( ce da ostane i unucicma ) za 3000 din i to ganc novo , a cena s popustom u radnji je bila 49 000 din .
Molm te da jos jednom procitas moj post ....UH sto ne volim da se ponavljam...Radi se o aparatu za tackasto zavarivanje.dok ti procitas ja odoh da listam Limundo....
Skonto sam te i za tackasti aparat ali se nikad nisam bavio izgradnjom/prepravkom bilo kog aparata za zavarivanje pa nisam nista mogao da ti odgovorim , a stavri koje ne znam uglavnom cutim o njima
Tenzore jel po volji ovaj aparat trenutno sam u teskim pregovorima
evo i neki forum gde se mnogo bolje vidi
http://www.pirate4x4.com/forum/showthread.php?t=784894 [40]
Koliko vidim, to je ko u onom vicu, taj aparat je samo za odlikaše.
A o ceni bolje da i ne pitam. :nes
Nije strasno izaslo bi malo vise od 1000 zavisi od prevoza,najveci problem je upravo to jer je aparat tezak 137 kg-tesko za utovar i transport,o nekom spediteru ni govora.To sto je tezak znaci da je kvalitetnu izradu starog tipa
nema mosfetova i chopera cist bakar!
Svidja mi se to sto aparat sam mesa gasove kad je potrebna mesavina npr hellijum.E sad pitanje nije li malo previse za moje potrebe?
Pa sve zavisi za šta ćeš da ga koristiš.Ako će ti biti izvor prihoda na neki način, bilo kao osnovna ili dopunska varijanta, onda je investicija ok, a ako ti služi samo za hoby, čitaj malo za zabavu, e onda je tu nemoguće dati savet.Neko potroši toliko para da ode na more 10 dana i više nema ništa, a ovako tih 1000 uloženih evropskih novčanica ostaje negde u radionici i ako ništa drugo aparat se opet može prodati jednog dana za neku sumu.Prema tome novac neće propasti sigurno.
Što se transporta tiče može se natovariti u auto prikolicu, dobro vezati i to je to.Ili da se transportuje u nekom kombiju.Za utovar se može koristiti strma ravan.Dve kraće fosne i dva snažna momka i aparat je utovaren.
[1] http://www.samsvojmajstor.com/portal/sites/default/files/untitled_103.jpg
[2] http://www.samsvojmajstor.com/portal/sites/default/files/untitled_100.jpg
[3] http://www.samsvojmajstor.com/portal/sites/default/files/_1260559477904.png
[4] http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/da-li-je-neko-video-ovaj-aparat-ili-mozda-radio-s-njim#comment-319377
[5] http://www.samsvojmajstor.com/portal/users/tenzor
[6] https://www.facebook.com/tenzor1/
[7] https://tenzorisanje.wordpress.com/
[8] https://www.youtube.com/channel/UCHEOtDmyQYSMVXVjjyVsWkw
[9] http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/da-li-je-neko-video-ovaj-aparat-ili-mozda-radio-s-njim#comment-319378
[10] http://www.alibaba.com/product-gs/223314700/welding_TIG_welding_ARC_welding_machine.html
[11] http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/da-li-je-neko-video-ovaj-aparat-ili-mozda-radio-s-njim#comment-319379
[12] http://www.samsvojmajstor.com/portal/users/demian
[13] http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/da-li-je-neko-video-ovaj-aparat-ili-mozda-radio-s-njim#comment-319380
[14] http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/da-li-je-neko-video-ovaj-aparat-ili-mozda-radio-s-njim#comment-319381
[15] http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/da-li-je-neko-video-ovaj-aparat-ili-mozda-radio-s-njim#comment-319382
[16] http://www.samsvojmajstor.com/portal/users/maradona
[17] http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/da-li-je-neko-video-ovaj-aparat-ili-mozda-radio-s-njim#comment-319383
[18] http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/da-li-je-neko-video-ovaj-aparat-ili-mozda-radio-s-njim#comment-319384
[19] http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/da-li-je-neko-video-ovaj-aparat-ili-mozda-radio-s-njim#comment-319385
[20] http://lh4.ggpht.com/__h_z3yOGmKg/SuNJUjsSCvI/AAAAAAAAATc/1gPQcU-zwgE/s400/DSC02609.JPG
[21] http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/da-li-je-neko-video-ovaj-aparat-ili-mozda-radio-s-njim#comment-319386
[22] http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/da-li-je-neko-video-ovaj-aparat-ili-mozda-radio-s-njim#comment-319387
[23] http://www.samsvojmajstor.com/portal/users/zorani
[24] http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/da-li-je-neko-video-ovaj-aparat-ili-mozda-radio-s-njim#comment-319388
[25] http://www.samsvojmajstor.com/portal/users/gogi
[26] http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/da-li-je-neko-video-ovaj-aparat-ili-mozda-radio-s-njim#comment-319389
[27] http://www.weldingtipsandtricks.com/wasted-200-bucks-on-chinese-welder.html
[28] http://www.weldingtipsandtricks.com/no-homework-no-reason-to-complain.html
[29] http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/da-li-je-neko-video-ovaj-aparat-ili-mozda-radio-s-njim#comment-319390
[30] http://www.samsvojmajstor.com/portal/users/zvukoljub
[31] http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/da-li-je-neko-video-ovaj-aparat-ili-mozda-radio-s-njim#comment-319391
[32] http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/da-li-je-neko-video-ovaj-aparat-ili-mozda-radio-s-njim#comment-319392
[33] http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/da-li-je-neko-video-ovaj-aparat-ili-mozda-radio-s-njim#comment-319393
[34] http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/da-li-je-neko-video-ovaj-aparat-ili-mozda-radio-s-njim#comment-319394
[35] http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/da-li-je-neko-video-ovaj-aparat-ili-mozda-radio-s-njim#comment-319395
[36] http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/da-li-je-neko-video-ovaj-aparat-ili-mozda-radio-s-njim#comment-319396
[37] http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/da-li-je-neko-video-ovaj-aparat-ili-mozda-radio-s-njim#comment-319397
[38] http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/da-li-je-neko-video-ovaj-aparat-ili-mozda-radio-s-njim#comment-319398
[39] http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/da-li-je-neko-video-ovaj-aparat-ili-mozda-radio-s-njim#comment-319399
[40] http://www.pirate4x4.com/forum/showthread.php?t=784894
[41] http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/da-li-je-neko-video-ovaj-aparat-ili-mozda-radio-s-njim#comment-319400
[42] http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/da-li-je-neko-video-ovaj-aparat-ili-mozda-radio-s-njim#comment-319401
[43] http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/da-li-je-neko-video-ovaj-aparat-ili-mozda-radio-s-njim#comment-319402
[44] http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija
Bice da je u pitanju genericki kineski prozivod . Jel sto bi trebalo da dosta govori o njemu i o kvalitetu istog no ne mora da znaci da je bas smece . Cena od oko 300 -ak E govori da spada u nizu klasu . Pogotovo sto u tu cenu ulazi i pedala i komplet za tig . E sad zavisi za koje namene bi se koristio ne verujem da moze da zadovolji od neke srednje upotrebe u manjoj radionici .
Inace su i na inostranim zavarivackim forumima misljenja vrlo podeljena ali ga svi max ocenjuju kao SSM tj hobyy masinu
https://www.facebook.com/tenzor1/ [6]
https://tenzorisanje.wordpress.com/ [7]
https://www.youtube.com/channel/UCHEOtDmyQYSMVXVjjyVsWkw [8]
