Answer for ironmaiden:
P19 does not represent a time. It indicates the minimum number of pellet insertion(+pause) for the current power before switching to the next power ("Broj ciklusa doziranja(rad+pauza) pre promene snage")
For example, if p19=3 and if the current power is Power4, it will do at least 3 ON/OFF cycles of Power4 before switching to Power5 or Power3.
Also, if you limit the maximum power from the user menu, you will notice that it will use the new power only if p19 cycles have passed.
Slazem se za pisanje, samo eto direktno odgovorih. Izvinjenje svim clanovima. Sa onim korekcijama za doziranje sam postigao smanjenje ili povecanje duzine rada puza po svima snagama. Na.pr.sa korekcijom +2 (=20) produzio sam rad puza za 20% od vremena setovanog samim parametrom za odredjenu snagu. Ovako se direktno utice na snagu kotla a bez odlaska u servisni meni.
