Hvala! Stvar je u tome da mi cerkica ima vec 6 mjeseci, a kada sam pocinjao bas, trebalo je da se rodi za par dana
Paznja mi je bila strasno podijeljena Drugo, dio ovog rada je od prosle godine, jer sam narezao dosta polufabrikata, sto mi se sad dosta isplati. Imam spremnih dijelova za 5 ovakvih gitara.
Gitarska Radionica
[IMG]http://imageshack.us/a/img547/6179/1img20130113125126.jpg[/IMG]
[IMG]http://imageshack.us/a/img812/543/2img20130113130348.jpg[/IMG]
[IMG]http://imageshack.us/a/img442/166/3img20130113131750.jpg[/IMG]
[IMG]http://imageshack.us/a/img824/7562/4img20130113131807.jpg[/IMG]
[IMG]http://imageshack.us/a/img607/236/img20130115090233.jpg[/IMG]
[IMG]http://imageshack.us/a/img145/4521/img20130115091348.jpg[/IMG]
[IMG]http://imageshack.us/a/img339/3056/img20130115092324.jpg[/IMG]
[IMG]http://imageshack.us/a/img217/1731/img20130115093058.jpg[/IMG]
[IMG]http://imageshack.us/a/img829/7919/1img20130115133743.jpg[/IMG]
[IMG]http://imageshack.us/a/img338/6432/2img20130115135513.jpg[/IMG]
[IMG]http://imageshack.us/a/img267/4669/3img20130115135519.jpg[/IMG]
[IMG]http://imageshack.us/a/img571/4083/4img20130115140559.jpg[/IMG]
[IMG]http://imageshack.us/a/img560/8583/1img20130116143917.jpg[/IMG]
[IMG]http://imageshack.us/a/img259/5829/2img20130116144638.jpg[/IMG]
[IMG]http://imageshack.us/a/img202/2808/3img20130116145826.jpg[/IMG]
[IMG]http://imageshack.us/a/img687/8991/4img20130116150555.jpg[/IMG]
[IMG]http://imageshack.us/a/img202/3970/5img20130116151012.jpg[/IMG]
[IMG]http://imageshack.us/a/img72/148/6img20130116152044.jpg[/IMG]
[IMG]http://imageshack.us/a/img822/917/7img20130116152901.jpg[/IMG]
[IMG]http://imageshack.us/a/img585/952/8img20130116153959.jpg[/IMG]
[IMG]http://imageshack.us/a/img248/7301/img20130118085325.jpg[/IMG]
[IMG]http://imageshack.us/a/img23/1414/img20130118095655.jpg[/IMG]
[IMG]http://imageshack.us/a/img534/5321/img20130118095704.jpg[/IMG]
[IMG]http://imageshack.us/a/img202/1491/img20130118100522.jpg[/IMG]
[IMG]http://imageshack.us/a/img252/215/img20130118101706.jpg[/IMG]
[IMG]http://imageshack.us/a/img42/9595/img20130120132402.jpg[/IMG]
[IMG]http://imageshack.us/a/img46/6130/img20130120132413.jpg[/IMG]
[IMG]http://imageshack.us/a/img90/5613/img20130121083202.jpg[/IMG]
[IMG]http://imageshack.us/a/img7/3715/img20130121091052.jpg[/IMG]
[IMG]http://imageshack.us/a/img836/8080/img20130121100246.jpg[/IMG]
E pa neverujem da imaš ovo malo rende!!! Pa ja to mesecima tražim po buvljacima..bezuspešno.. Možeš li mi pribaviti jedno isto takvo..nepitam šta košta!
Evo linka, salju u Srbiju bez problema, mozes da platis karticom. Nije jeftino, ali je vjecno. Livena bronza, a ja svoju od 10mm imam negdje od 2000te npr, i do sada nisam ni ostrio noz, a podesavap sam je prije bar 3 godine, tj nemas sta da radis oko nje, samo radis. Alternativa bi bila da vidis neke za violine, ako mozes naci nekog majstoa koji vise ne radi, ali ovo je po meni najbolja varijanta. Mozda neko od metalaca ovdje moze da napravi?
Inace, ove manje su grube za ruke, prave ozbiljne zuljeve, pa ti trebaju neke rukavice, ja omotavam prste papirnom trakom itd...
http://www.stewmac.com/shop/Tools/Planes/Ibex_Convex_Finger_Planes.html
http://www.stewmac.com/shop/Tools/Planes/Ibex_Palm_Plane.html
[IMG]http://imageshack.us/a/img40/1662/img20130122093105.jpg[/IMG]
[IMG]http://imageshack.us/a/img842/5710/img20130122094724.jpg[/IMG]
[IMG]http://imageshack.us/a/img824/8513/img20130122094735.jpg[/IMG]
[IMG]http://imageshack.us/a/img545/8208/img20130122095028.jpg[/IMG]
Palo mi je na pamet da malo procackam google, i pazi sad:
http://www.studioboone.com/guitars/fingerplane.html
http://dunwellguitar.com/FingerPlanes/MyDesign.htm
Mislim da nije problem da se napravi, mozda i ja napravim jednu malo vecu od moje, mnogo mi pravi zuljeve...imam komadica tresnje i javora ovih dana
za noz bi mogao komadic lista pile za metal?
UF kad sam rekao da nepitam šta košta nisam mislio baš na ovoliku sumu
.. Inače možda se i bacim na izradu dotičnog predmeta, ima i na You Tube-u jedan zgodan klip ali nikako da ga nađem.. Pričekaću još malo a do tad poziv stoji svakom ko ima ovaj rendić a nekoristi ga - vrlo rado bih ga otkupio! Meni je baš potreban..
Hvala Popgtrs na predlozima!
ja sam to kupio u zlatna vremena, sad bi se tesko odlucio da dam tolike pare!
Sad sam ozbiljno zagolican da napravim par komada, samo da uhvatim malo vremena...Da te racunam za jedan-dva kom?
Obavezno me računaj! Ja za ove moje sitne radove baš imam potrebu za tako malim rendićem.. Ako treba kakva filozofska ili finansijska podrška samo zovi!
OK, javljam!
[IMG]http://imageshack.us/a/img28/3470/1img20130124114139.jpg[/IMG]
[IMG]http://imageshack.us/a/img202/5010/2img20130124124215.jpg[/IMG]
[IMG]http://imageshack.us/a/img824/1192/3img20130124124232.jpg[/IMG]
[IMG]http://imageshack.us/a/img651/8724/1img20130125140111.jpg[/IMG]
[IMG]http://imageshack.us/a/img41/8989/2img20130125140146.jpg[/IMG]
[IMG]http://imageshack.us/a/img836/271/1img20130127082101.jpg[/IMG]
[IMG]http://imageshack.us/a/img163/8973/2img20130127082116.jpg[/IMG]
[IMG]http://imageshack.us/a/img12/6164/1img20130130145240.jpg[/IMG]
[IMG]http://imageshack.us/a/img547/5279/2img20130131121058.jpg[/IMG]
[IMG]http://imageshack.us/a/img42/8/3img20130131121751.jpg[/IMG]
[IMG]http://imageshack.us/a/img812/5826/4img20130131122840.jpg[/IMG]
[IMG]http://imageshack.us/a/img268/469/5img20130131122849.jpg[/IMG]
[IMG]http://imageshack.us/a/img89/1072/6img20130131123755.jpg[/IMG]
[IMG]http://imageshack.us/a/img820/9582/7img20130131124709.jpg[/IMG]
[IMG]http://imageshack.us/a/img593/7559/8img20130131131828.jpg[/IMG]
[IMG]http://imageshack.us/a/img545/8114/9img20130131131837.jpg[/IMG]
[IMG]http://imageshack.us/a/img20/1676/1img20130204125418.jpg[/IMG]
[IMG]http://imageshack.us/a/img210/1464/2img20130206114058.jpg[/IMG]
Malo se hladim od smirglanja pilajuci jos polufabrikata. Usput iskoristim sve sto moze da se pretvori u neki dio gitare, a komadici idu u kotao...
Spremam se za lakiranje, a u medjuvremenu sam isjekao i palac na bansek, sreca pa sam nosio rukavice inace bi i vise...znaci, oprezno sa masinama
Tetanus, umotana ruka, 2000mg Palitreksa dnevno i saka brufena
[IMG]http://imageshack.us/a/img7/7679/3img20130219170917.jpg[/IMG]
[IMG]http://imageshack.us/a/img51/8274/2img20130219171021.jpg[/IMG]
[IMG]http://imageshack.us/a/img822/4396/1img20130220084547.jpg[/IMG]
[IMG]http://imageshack.us/a/img708/8074/1img20130220112933.jpg[/IMG]
[IMG]http://imageshack.us/a/img836/2618/2img20130220123322.jpg[/IMG]
[IMG]http://imageshack.us/a/img266/8620/1img20130220190340.jpg[/IMG]
[IMG]http://imageshack.us/a/img593/9303/2img20130220190325.jpg[/IMG]
[IMG]http://imageshack.us/a/img593/2645/3img20130220190312.jpg[/IMG]
[IMG]http://imageshack.us/a/img17/7711/4img20130220190238.jpg[/IMG]
[IMG]http://imageshack.us/a/img543/1206/1img20130221113839.jpg[/IMG]
[IMG]http://imageshack.us/a/img547/8075/1img20130223133559.jpg[/IMG]
Majstore šta si nam zanemeo? nije valjda zbog prsta?
.. Kaži nam malo čime si farbao?
ps. da ti malo olakšam muke.. Pre nekih dva meseca sam montirao na brusilicu mini list za cirkular (predviđen za tu namenu).. Posle dva minuta sečenja naiđem na neki čudan čvor i iskoči brusilica direktno na levu ruku.. Sreća u nesreći - 5 šavova iznad korena palca ali Bogu hvala funkcija i dužina svih prstiju sačuvana..
Ajd uzdravlje i samo napred..
Reko sve se vidi i iz slika, a i nije da se bas puno komentarise
Dobro si prosao, zvuci bas opasno - ja sam presao bansekom popreko jagodice, od nokta do nokta, jako bolno poslije par par sati...sutra skidam zavoje, pa prelazim na hanzaplaste. Sreca da sam nosio rukavice, a i to uglavnom sto je bilo pomalo hladno... Doktori ko doktori, nije bilo sivanja, a onda mi ovaj za kontrole kaze da su trebale 2 kopce.
Sto se gitare tice, ovo je nitro bajc na golo drvo, spricano, a cu da lakiram 2komponentnim lakom koji su mi preporucili kod istog distributera. 60-70% sjaja. Trebalo bi da je suv za par sati. U retrospektivi, radije bi radio kao i dosad - ledja moze da golo drvo, a lice 1 ruka laka, pa onda bajc, jer sarenilo drveyta ako nije ravnomjerno, moze da malo pravi problem ako radim prelaz.
Prelaz moze malo da se finesira finom smirglom, npr 800.
Majstorski, nema šta! Mada koliko vidim kod ove druge si mnogo ažurniji nego sa onim basom.. Dosta brže ti ide..
Samo napred, mi pojedini pratimo pomno tvoje radove..
